I tried to build my game with 64 bit enable and FMOD plugin turned on.
I changed armeabi-v7a folder name to arm64-v8a and start packaging.
I received following error:
MainFrameActions: Packaging (Android (ASTC)): UnrealBuildTool: Compiling Native code with NDK API 'android-21'
MainFrameActions: Packaging (Android (ASTC)): UnrealBuildTool: Performing 1 actions (4 in parallel)
MainFrameActions: Packaging (Android (ASTC)): UnrealBuildTool: [1/1] clang++.exe CHASERS-arm64-es31.so
MainFrameActions: Packaging (Android (ASTC)): UnrealBuildTool: D:/NVPACK/android-ndk-r11c/toolchains/aarch64-linux-android-4.9/prebuilt/windows-x86_64/lib/gcc/aarch64-linux-android/4.9/../../../../aarch64-linux-android/bin\ld: skipping incompatible F:/gameDNAstudio/HelixCloud/CHASERS/Plugins/FMODStudi
MainFrameActions: Packaging (Android (ASTC)): o/Source/FMODStudio/../../Binaries/Android/arm64-v8a/libfmodL.so when searching for -lfmodL
MainFrameActions: Packaging (Android (ASTC)): UnrealBuildTool: D:/NVPACK/android-ndk-r11c/toolchains/aarch64-linux-android-4.9/prebuilt/windows-x86_64/lib/gcc/aarch64-linux-android/4.9/../../../../aarch64-linux-android/bin\ld: cannot find -lfmodL
MainFrameActions: Packaging (Android (ASTC)): o/Source/FMODStudio/../../Binaries/Android/arm64-v8a/libfmodstudioL.so when searching for -lfmodstudioL
MainFrameActions: Packaging (Android (ASTC)): UnrealBuildTool: D:/NVPACK/android-ndk-r11c/toolchains/aarch64-linux-android-4.9/prebuilt/windows-x86_64/lib/gcc/aarch64-linux-android/4.9/../../../../aarch64-linux-android/bin\ld: cannot find -lfmodstudioL
MainFrameActions: Packaging (Android (ASTC)): UnrealBuildTool: clang++.exe: error: linker command failed with exit code 1 (use -v to see invocation)
