eyc
                    October 25, 2016,  6:52pm
              1
              Is anyone using UE4 4.13 + FMOD for Google Daydream? It works in the editor with mobile preview, but when it’s deployed to the device, I hear no FMOD sounds. It appears that all the library files, fmod.jar, libfmod.so, libfmodstudio.so, libgvraudio.so are being correctly packaged up. And it looks like GameActivity.java is loading the fmod and gvraudio libraries. Here’s a snippet of  GameActivity.java:
try
System.loadLibrary(“fmod”);
catch (java.lang.UnsatisfiedLinkError e)
Log.debug(“libfmod not loaded and required!”);
try
System.loadLibrary(“fmodstudio”);
Log.debug(“libfmodstudio not loaded and required!”);
try
System.loadLibrary(“gvraudio”);
Log.debug(“gvraudio not loaded and required!”);
I tried looking at the adb logcat output, but there’s only one entry for fmod,
I fmod    : FMOD::supportsLowLatency                 : Low latency = true, Pro Audio = true, Acceptable Block Size = true (192)
Does anyone have any suggestions about how to proceed? Thanks in advance for any help.
                eyc
                    October 27, 2016,  5:44pm
              2
try
try
try
I might have been running adb logcat with some bad parameters. Here’s the FMOD output from a clean run of adb logcat (looks like Gvr Audio Listener Plugin is missing, so that’s probably Google’s problem):
--------- beginning of main
--------- beginning of system
10-27 10:37:28.287 13397 13417 D UE4     : [2016.10.27-17.37.28:287][  0]LogPluginManager: Loaded Plugin FMODStudio, From …/…/…/ExampleUnrealProject/Plugins/FMODStudio/FMODStudio.uplugin
10-27 10:37:28.334 13397 13417 I fmod    : FMOD::supportsLowLatency                 : Low latency = true, Pro Audio = true, Acceptable Block Size = true (192)
10-27 10:37:28.539 13397 13417 D UE4     : [2016.10.27-17.37.28:539][  0]LogFMODOculus: StartupModule
10-27 10:37:28.539 13397 13417 D UE4     : [2016.10.27-17.37.28:539][  0]LogFMOD: FFMODStudioModule startup
10-27 10:37:28.540 13397 13417 D UE4     : [2016.10.27-17.37.28:540][  0]LogFMOD:  Lib path = ‘…/…/…/ExampleUnrealProject/Plugins/FMODStudio/Binaries’
10-27 10:37:28.540 13397 13417 D UE4     : [2016.10.27-17.37.28:540][  0]LogFMOD: Loading strings bank: …/…/…/ExampleUnrealProject/Content/FMOD/Mobile/Master Bank.strings.bank
10-27 10:37:28.540 13397 13417 D UE4     : [2016.10.27-17.37.28:540][  0]LogFMOD: Skipping asset: bus:/
10-27 10:37:28.540 13397 13417 D UE4     : [2016.10.27-17.37.28:540][  0]LogFMOD: Constructing asset: /Game/FMOD/Events/New_Event
10-27 10:37:28.540 13397 13417 D UE4     : [2016.10.27-17.37.28:540][  0]LogFMOD: Skipping asset: bank:/Master Bank.strings
10-27 10:37:28.540 13397 13417 D UE4     : [2016.10.27-17.37.28:540][  0]LogFMOD: Constructing asset: /Game/FMOD/Banks/Master_Bank
10-27 10:37:28.541 13397 13417 D UE4     : [2016.10.27-17.37.28:540][  0]LogFMOD: Creating runtime Studio System
10-27 10:37:28.541 13397 13417 D UE4     : [2016.10.27-17.37.28:541][  0]LogFMOD: Default sample rate = 24000
10-27 10:37:28.541 13397 13417 D UE4     : [2016.10.27-17.37.28:541][  0]LogFMOD: System sample rate = 48000
10-27 10:37:28.541 13397 13417 D UE4     : [2016.10.27-17.37.28:541][  0]LogFMOD:Warning: …/…/src/fmod_systemi.cpp(2706) - Output requires a sample rate of 48000Hz, resampling will occur.
10-27 10:37:28.541 13397 13417 D UE4     : [2016.10.27-17.37.28:541][  0]LogFMOD: Loading plugin ‘gvraudio’
10-27 10:37:28.542 13397 13417 D UE4     : [2016.10.27-17.37.28:541][  0]LogFMOD: Trying to load plugin file at location: gvraudio.so
10-27 10:37:28.542 13397 13417 D UE4     : [2016.10.27-17.37.28:542][  0]LogFMOD:Error: …/android/src/fmod_os_misc.cpp(998) - dlopen failed: library “gvraudio.so” not found
10-27 10:37:28.542 13397 13417 D UE4     : [2016.10.27-17.37.28:542][  0]LogFMOD: Trying to load plugin file at location: gvraudio32.so
10-27 10:37:28.542 13397 13417 D UE4     : [2016.10.27-17.37.28:542][  0]LogFMOD:Error: …/android/src/fmod_os_misc.cpp(998) - dlopen failed: library “gvraudio32.so” not found
10-27 10:37:28.543 13397 13417 D UE4     : [2016.10.27-17.37.28:543][  0]LogFMOD: Trying to load plugin file at location: libgvraudio.so
10-27 10:37:28.543 13397 13417 D UE4     : [2016.10.27-17.37.28:543][  0]LogFMOD: Loaded plugin gvraudio
10-27 10:37:28.543 13397 13417 D UE4     : [2016.10.27-17.37.28:543][  0]LogFMOD: Triggering Initialized on other modules
10-27 10:37:28.543 13397 13417 D UE4     : [2016.10.27-17.37.28:543][  0]LogFMODOculus: FMOD_OSP_SUPPORTED is not enabled
10-27 10:37:28.543 13397 13417 D UE4     : [2016.10.27-17.37.28:543][  0]LogFMOD: Loading Banks
10-27 10:37:28.543 13397 13417 D UE4     : [2016.10.27-17.37.28:543][  0]LogFMOD:Warning: …/…/src/fmod_effect.cpp(189) - Missing DSP plugin ‘Gvr Audio Listener Plugin’
10-27 10:37:28.544 13397 13417 D UE4     : [2016.10.27-17.37.28:543][  0]LogFMOD:Error: …/…/src/fmod_bankmodel.cpp(247) - DSP plugin returned an error, bank will not load properly.
10-27 10:37:28.544 13397 13417 D UE4     : [2016.10.27-17.37.28:544][  0]LogFMOD:Warning: Failed to bank: …/…/…/ExampleUnrealProject/Content/FMOD/Mobile/Master Bank.bank (A requested output, dsp unit type or codec was not available.)
10-27 10:37:29.261 13397 13417 D UE4     : [2016.10.27-17.37.29:261][  0]LogFMOD:Warning: …/…/src/fmod_objectlookup.h(115) - Lookup failed for EventModel: {53e945c7-ab23-4d8d-8914-dca39ed82136}
