Unity integration may be crashing Unity editor if a callback references Unity GameObject
I’m experiencing Unity editor crashes with which FMOD may have something to do.
Using EventInstance::setCallback, I wrote a delegate which lets the UI element pulse via Animator.
    public StudioEventEmitter bgmEvent;
    [SerializeField] private Animator uiAnimator;
    private EVENT_CALLBACK beatPulseCallback;
    private void Start() {
        beatPulseCallback = StudioEventCallBack;
        bgmEvent.EventInstance.setCallback(
            beatPulseCallback, EVENT_CALLBACK_TYPE.TIMELINE_BEAT
    private RESULT StudioEventCallBack(EVENT_CALLBACK_TYPE type, EventInstance eventInstance, IntPtr parameters)
        Debug.Log("CB");
        if (uiAnimator != null)
            uiAnimator.SetTrigger("PulseTriggered");
        return RESULT.OK;
Note that the callback references an Animator during the procedure. This code appears to work until I exit the PlayMode when Unity editor crashes.
If I trigger the same code using other means (e.g. KeyDown,) I cannot observe any crashes.
The project that has this code is quite big, and the FMOD integration takes time to shut down when exiting the PlayMode, so I did some experiments.
When I move this code to a new empty project and try to reproduce it:
  • 70% of the time it doesn’t fail
  • 20% of the time it freezes the Unity editor, and
  • 10% of the time the code crashes it.
When it freezes the editor, it usually leaves a NullReferenceException before its demise. The funny thing is that the exception occurs at if (uiAnimator != null) part - the null check itself is returning an NRE, which should not happen.
Then I added an OnDestroy() method to remove the callback before quitting:
    private void OnDestroy() {
        bgmEvent.EventInstance.setCallback(null);
        bgmEvent.Stop();
And this code seems to mitigate the crash altogether (and that’s what I currently do to avoid it.) However, when I stop the event before removing callbacks, the editor crashes.
Based on the observations, I suspect that the callback can be being triggered after the Unity context is destroyed - and if the callback happens to reference GameObjects, everything goes haywire since the underlying reference is gone.
Can you confirm if my suspicion is correct? If it is, I consider this issue a bug (or at least should be documented somehow? AFAIR there is no mention of the danger of referencing GameObjects in callbacks - this example does not seem to clear callbacks in OnDestroy method.)
OS: macOS Catalina 10.15.3.
Unity version: 2019.3.3f1.
FMOD Studio/Unity Integration version: 2.00.07.
I have not been able to reproduce the issue here, but it may have something to do with the callback function. You may need to add MonoPInvokeCallbackAttribute as a custom attribute and make the function static.
Currently, only static methods can be passed as delegates to the native code.
I can approve to this message for I have experience the same thing and the only way is through handling the StudioEventCallBack with a static keyword.
Worth the pain to try and break the norm :))
