Unity Integration Tutoria Issue (No sound in Unity)
Hello!
I’m following the FMOD integration tutorial with Unity step by step, and everything has been working fine until I got to section 3.4, Adding Sounds: Kart Engine.
https://fmod.com/docs/2.02/unity/integration-tutorial.html
In that section, step 8 (“Play the game. You should now hear the kart engine playing at a constant RPM value of 1000”), I can’t hear any sound inside Unity. Unity’s internal audio is disabled. I have installed FMOD for Unity and have FMOD Studio open. However, when I press play on the game in Unity, I get a lot of errors in the console (end of the post).
My versions are:
Unity: 2021.3.45f2
FMOD: 2.03
FMOD For Unity: 2.03
I’m sorry, but I’m not a Unity user and I don’t know what any of these errors mean, although I am interested in learning how to integrate FMOD with the game engine. I would greatly appreciate any help.
Cheers!
[FMOD] Unable to load Dialogue_EN - bank already loaded. This may occur when attempting to load another localized bank before the first is unloaded, or if a bank has been loaded via the API.
UnityEngine.Debug:LogWarningFormat (string,object)
FMODUnity.RuntimeUtils:DebugLogWarningFormat (string,object) (at Assets/Plugins/FMOD/src/RuntimeUtils.cs:588)
FMODUnity.RuntimeManager:RegisterLoadedBank (FMODUnity.RuntimeManager/LoadedBank,string,string,bool,FMOD.RESULT) (at Assets/Plugins/FMOD/src/RuntimeManager.cs:862)
FMODUnity.RuntimeManager:LoadBank (string,bool,string) (at Assets/Plugins/FMOD/src/RuntimeManager.cs:971)
FMODUnity.RuntimeManager:LoadBank (string,bool) (at Assets/Plugins/FMOD/src/RuntimeManager.cs:922)
FMODUnity.RuntimeManager:LoadBanks (FMODUnity.Settings) (at Assets/Plugins/FMOD/src/RuntimeManager.cs:1054)
FMODUnity.RuntimeManager:Initialize () (at Assets/Plugins/FMOD/src/RuntimeManager.cs:411)
FMODUnity.RuntimeManager:get_Instance () (at Assets/Plugins/FMOD/src/RuntimeManager.cs:212)
FMODUnity.RuntimeManager:get_StudioSystem () (at Assets/Plugins/FMOD/src/RuntimeManager.cs:230)
FMODUnity.StudioListener:AddListener (FMODUnity.StudioListener) (at Assets/Plugins/FMOD/src/StudioListener.cs:97)
FMODUnity.StudioListener:OnEnable () (at Assets/Plugins/FMOD/src/StudioListener.cs:127)
[FMOD] Unable to load Dialogue_JP - bank already loaded. This may occur when attempting to load another localized bank before the first is unloaded, or if a bank has been loaded via the API.
[FMOD] PluginEffectModel::init : Missing DSP plugin ‘FMOD Haptics’
UnityEngine.Debug:LogWarning (object)
FMODUnity.RuntimeUtils:DebugLogWarning (string) (at Assets/Plugins/FMOD/src/RuntimeUtils.cs:580)
FMODUnity.RuntimeManager:DEBUG_CALLBACK (FMOD.DEBUG_FLAGS,intptr,int,intptr,intptr) (at Assets/Plugins/FMOD/src/RuntimeManager.cs:108)
[FMOD] PostLoad::initPluginEffects : DSP plugin returned an error, bank will not load properly.
UnityEngine.Debug:LogError (object)
FMODUnity.RuntimeUtils:DebugLogError (string) (at Assets/Plugins/FMOD/src/RuntimeUtils.cs:596)
FMODUnity.RuntimeManager:DEBUG_CALLBACK (FMOD.DEBUG_FLAGS,intptr,int,intptr,intptr) (at Assets/Plugins/FMOD/src/RuntimeManager.cs:104)
BankLoadException: [FMOD] Could not load bank ‘../../Audio Projects/FMOD/Karting Examples/Build/Desktop/Haptics.bank’ : ERR_PLUGIN_MISSING : A requested output, dsp unit type or codec was not available.
FMODUnity.RuntimeManager.RegisterLoadedBank (FMODUnity.RuntimeManager+LoadedBank loadedBank, System.String bankPath, System.String bankName, System.Boolean loadSamples, FMOD.RESULT loadResult) (at Assets/Plugins/FMOD/src/RuntimeManager.cs:866)
FMODUnity.RuntimeManager.LoadBank (System.String bankName, System.Boolean loadSamples, System.String bankId) (at Assets/Plugins/FMOD/src/RuntimeManager.cs:971)
FMODUnity.RuntimeManager.LoadBank (System.String bankName, System.Boolean loadSamples) (at Assets/Plugins/FMOD/src/RuntimeManager.cs:922)
FMODUnity.RuntimeManager.LoadBanks (FMODUnity.Settings fmodSettings) (at Assets/Plugins/FMOD/src/RuntimeManager.cs:1054)
UnityEngine.Debug:LogException(Exception)
FMODUnity.RuntimeUtils:DebugLogException(Exception) (at Assets/Plugins/FMOD/src/RuntimeUtils.cs:612)
FMODUnity.RuntimeManager:LoadBanks(Settings) (at Assets/Plugins/FMOD/src/RuntimeManager.cs:1061)
FMODUnity.RuntimeManager:Initialize() (at Assets/Plugins/FMOD/src/RuntimeManager.cs:411)
FMODUnity.RuntimeManager:get_Instance() (at Assets/Plugins/FMOD/src/RuntimeManager.cs:212)
FMODUnity.RuntimeManager:get_StudioSystem() (at Assets/Plugins/FMOD/src/RuntimeManager.cs:230)
FMODUnity.StudioListener:AddListener(StudioListener) (at Assets/Plugins/FMOD/src/StudioListener.cs:97)
FMODUnity.StudioListener:OnEnable() (at Assets/Plugins/FMOD/src/StudioListener.cs:127)
[FMOD] ObjectLookup::get : Lookup failed for EventModel: {7aa5e8f1-8ec2-42c6-b465-1241a603a055}
FMOD.Studio.System:getEventByID (FMOD.GUID,FMOD.Studio.EventDescription&) (at Assets/Plugins/FMOD/src/fmod_studio.cs:464)
FMODUnity.RuntimeManager:GetEventDescription (FMOD.GUID) (at Assets/Plugins/FMOD/src/RuntimeManager.cs:1367)
FMODUnity.RuntimeManager:GetEventDescription (FMODUnity.EventReference) (at Assets/Plugins/FMOD/src/RuntimeManager.cs:1338)
FMODUnity.StudioEventEmitter:Lookup () (at Assets/Plugins/FMOD/src/StudioEventEmitter.cs:193)
FMODUnity.StudioEventEmitter:Play () (at Assets/Plugins/FMOD/src/StudioEventEmitter.cs:222)
FMODUnity.StudioEventEmitter:HandleGameEvent (FMODUnity.EmitterGameEvent) (at Assets/Plugins/FMOD/src/StudioEventEmitter.cs:183)
FMODUnity.StudioEventEmitter:Start () (at Assets/Plugins/FMOD/src/StudioEventEmitter.cs:130)
EventNotFoundException: [FMOD] Event not found: {7aa5e8f1-8ec2-42c6-b465-1241a603a055} (event:/Vehicles/Ride-on Mower)
FMODUnity.RuntimeManager.GetEventDescription (FMODUnity.EventReference eventReference) (at Assets/Plugins/FMOD/src/RuntimeManager.cs:1342)
FMODUnity.StudioEventEmitter.Lookup () (at Assets/Plugins/FMOD/src/StudioEventEmitter.cs:193)
FMODUnity.StudioEventEmitter.Play () (at Assets/Plugins/FMOD/src/StudioEventEmitter.cs:222)
FMODUnity.StudioEventEmitter.HandleGameEvent (FMODUnity.EmitterGameEvent gameEvent) (at Assets/Plugins/FMOD/src/StudioEventEmitter.cs:183)
FMODUnity.StudioEventEmitter.Start () (at Assets/Plugins/FMOD/src/StudioEventEmitter.cs:130)
Didn’t find audio group for HUDObjective
AudioUtility:GetAudioGroup (AudioUtility/AudioGroups) (at Assets/Karting/Scripts/Utilities/AudioUtility.cs:42)
ObjectiveToast:PlaySound (UnityEngine.AudioClip) (at Assets/Karting/Scripts/UI/ObjectiveToast.cs:183)
ObjectiveToast:Update () (at Assets/Karting/Scripts/UI/ObjectiveToast.cs:117)
Hi
Thank you for sharing the information and Log.
From the log, this issue appears to be caused by the FMOD Haptics plugin not being found when running the default example. This plugin was recently added to the default example project from FMOD 2.03.11, which is why you’re seeing this message.
In Unity, could you please try the following steps:
  1. From the top menu bar, go to FMOD → Edit Settings to open the FMOD Settings.
  2. Navigate to Platform Specific → Editor → Dynamic Plugins.
  3. Click the “+” button and add fmod_haptics to the list.
  4. Apply the changes and see if this resolves the issue.
You can also find more information about setting up the Haptics plugin here: FMOD - Plugins (fmod haptics setup)
We’re currently working on improving this workflow and documentation, and I’ll create a task to ensure a clearer setup guide is provided going forward.
Thank you for bringing this to our attention!
Hello! I had run into the same issue and this solution worked perfectly for me.
Thank you very much!
Had the same issue, this resolved it. Thanks for the help!
