Unity Recorder script (from Scripting Examples) has few seconds of delay
I’m trying to record gameplay with the Unity Recorder. I was pleased to see that there is now a scripting example that should allow to record the sound from FMOD. It does record sound, but it’s very much delayed (Example - the light dots should match the sound).
Here is what I did:
  1. Copy-pasted the code from here in a script in my project (Simply renamed the class)
  2. Added it to an empty GameObject in my scene
  3. Added an AudioListener to the same gameObject
  4. Enabled Unity Audio
  5. Set the Unity Audio Sample Rate to 48.000 (same as FMOD audio)
  6. Hit play
  7. I can hear the sound in double as planned, tho one of them is delayed by ~1 sec
  8. Started recording with Unity Recorder. In the video output, sound is delayed by a few seconds.
Settings:
I also tried the script on a different project on a different computer, same result.
Am I missing something, or is the script broken?
As a side note, the fact that FMOD struggles to work with Unity’s Recorder is a very big deal for us. I know that it’s 50% from your side and 50% from Unity’s side, but I believe that two tools that are both used hand in hand for a large portion of their users could figure something out together…
We figured out the problem!
The issue was that our FMOD output was using 6 channels, and Unity Audio was expecting 2.
As stated in the script, FMOD must be in Stereo (2 channels) and not Surround something. BUT it appears this must be done in FMOD Studio→Preferences→Build→Stereo. Note that in Unity→FMODSettings there is a similar setting but it doesn’t appear to work for this issue.
Happy to hear that you managed to resolve the issue!
As far as I’m aware, the internal speakermode of the FMOD mixer shouldn’t make any impact on the recording latency, since the capture DSP that’s inserted into the mixer is set up so that incoming audio is downmixed to stereo. It more likely that there’s some interaction between Unity/FMOD’s audio buffer sizes, and the Unity recorder.
If you’re able to reproduce the issue again, could I get your exact Unity and FMOD for Unity versions, as well as screenshots of your settings for the Unity Recorder and ScriptUsageUnityRecorder component?
Here are our current settings:
I tried reverting back to surround 5.1 in the FMOD studio settings (then some other FMOD settings in Unity) I couldn’t reproduce the issue we had before so idk. Tho we did try many times with different settings, including the ones we have now, before switching to stereo in FMOD studio which immediatly fixed the issue. Maybe rebuilding the banks simply triggered a refresh somewhere which was needed for some setting to take effect or something.
Either way, we tried recording FMOD audio output directly using the script given by stenjus in this other thread: Can't record with Unity Recorder - #6 by stenjus (we used it simply to get the .wav file and got rid of the video and ffmpeg stuff). We could confirm at this point that our audio was using 6 channels, while the ScriptUsageUnityRecorder is supposed to work for stereo only. When we went down to 2 channels (we assumed thanks to the change in fmod studio), the script worked correctly.
Here is our version of ScriptUsageUnityRecorder (copy pasted, simply renamed I think):
// This is a Unity behaviour script that demonstrates how to capture
// FMOD's mixed audio output by creating a custom DSP and attaching it to
// the master channel group.
// The captured audio is then routed to Unity's OnAudioFilterRead callback
// so that it can be recorded by Unity Recorder.
// Steps to use:
// 1. Ensure Unity audio is enabled.
// 2. Attach this script to a GameObject that has an active AudioListener.
// 3. Ensure FMOD and Unity use the same sample rate and channel format (Mono or Stereo only).
//    Unity Recorder does not support channel formats above stereo (e.g., 5.1, 7.1).
// NOTE: In Editor Play (not recording) you may hear double monitoring:
// FMOD pass-through + Unity OnAudioFilterRead copy. This is expected.
// To avoid: temporarily mute the FMOD Master or route this GameObject to a silent Mixer.
// With Unity Recorder, the Listener is usually muted so double monitoring won't occur.
// This document assumes familiarity with Unity scripting. See
// https://unity3d.com/learn/tutorials/topics/scripting for resources
// on learning Unity scripting.
using System;
using UnityEngine;
#if UNITY_EDITOR
public class FMODRecorderHelper : MonoBehaviour
    private FMOD.DSP_READ_CALLBACK mReadCallback;
    private FMOD.DSP mCaptureDSP;
    private GCHandle mObjHandle;
    [Tooltip("Wait this many buffers before feeding Unity to avoid start noise")]
    [SerializeField, Min(0)]
    private int warmupBufferCount = 2;
    private int mFrontBufferPosition = 0;
    private Queue<float[]> mFullBufferQueue = new();
    private Queue<float[]> mEmptyBufferQueue = new();
    private readonly object lockOb = new();
    public static int nbChannelDetected = 0;
    void Start()
        // Prevent FMOD DSP initialization when not in Play Mode.
        if (!Application.isPlaying) return;
        // Validate Unity and FMOD audio config match
        var config = AudioSettings.GetConfiguration();
        int unitySampleRate = config.sampleRate;
        int unityChannels = config.speakerMode == AudioSpeakerMode.Stereo ? 2 : (int)config.speakerMode;
        int fmodSampleRate;
        FMOD.SPEAKERMODE fmodSpeakerMode;
        FMODUnity.RuntimeManager.CoreSystem.getSoftwareFormat(out fmodSampleRate, out fmodSpeakerMode, out _);
        int fmodChannels = fmodSpeakerMode == FMOD.SPEAKERMODE.STEREO ? 2 :
                           fmodSpeakerMode == FMOD.SPEAKERMODE.MONO ? 1 :
                           0; // Default to 0 for unsupported speaker modes(e.g. Surround)
        string unityFormat = unityChannels == 1 ? "Mono" :
                             unityChannels == 2 ? "Stereo" : "Unsupported";
        string fmodFormat = fmodChannels == 1 ? "Mono" :
                            fmodChannels == 2 ? "Stereo" : "Unsupported";
        if (fmodSampleRate != unitySampleRate || fmodChannels != unityChannels)
            Debug.LogError($"FMOD/Unity audio mismatch or unsupported channel format. Unity: {unitySampleRate}Hz/{unityFormat}, FMOD: {fmodSampleRate}Hz/{fmodFormat}\n" +
                           $"Please ensure FMOD and Unity use the same sample rate and channel layout (Mono or Stereo only).");
            enabled = false;
            return;
        mReadCallback = CaptureDSPReadCallback;
        mObjHandle = GCHandle.Alloc(this);
        var desc = new FMOD.DSP_DESCRIPTION
            numinputbuffers = 1,
            numoutputbuffers = 1,
            read = mReadCallback,
            userdata = GCHandle.ToIntPtr(mObjHandle)
        // Attach custom DSP to master channel group
        if (FMODUnity.RuntimeManager.CoreSystem.getMasterChannelGroup(out var masterCG) == FMOD.RESULT.OK)
            if (FMODUnity.RuntimeManager.CoreSystem.createDSP(ref desc, out mCaptureDSP) == FMOD.RESULT.OK)
                if (masterCG.addDSP(FMOD.CHANNELCONTROL_DSP_INDEX.TAIL, mCaptureDSP) == FMOD.RESULT.OK)
                    mCaptureDSP.setChannelFormat(FMOD.CHANNELMASK.STEREO, 2, FMOD.SPEAKERMODE.STEREO);
                else
                    Debug.LogWarning("FMOD: Failed to add DSP to master channel group.");
            else
                Debug.LogWarning("FMOD: Failed to create DSP.");
        else
            Debug.LogWarning("FMOD: Failed to retrieve master channel group.");
    [AOT.MonoPInvokeCallback(typeof(FMOD.DSP_READ_CALLBACK))]
    static FMOD.RESULT CaptureDSPReadCallback(ref FMOD.DSP_STATE dsp_state, IntPtr inbuffer, IntPtr outbuffer, uint length, int inchannels, ref int outchannels)
        var functions = dsp_state.functions;
        functions.getuserdata(ref dsp_state, out var userData);
        var objHandle = GCHandle.FromIntPtr(userData);
        var obj = objHandle.Target as FMODRecorderHelper;
        if (inchannels > nbChannelDetected)
            nbChannelDetected = inchannels;
        if (inchannels > 2)
            Debug.LogError("Channels FMOD > 2!");
            inchannels = 2;
        int lengthElements = (int)length * inchannels;
        float[] buffer;
        // Try to reuse a managed buffer of the exact size to reduce GC pressure.
        lock (obj.lockOb)
            if (obj.mEmptyBufferQueue.Count > 0)
                var tmp = obj.mEmptyBufferQueue.Dequeue();
                buffer = (tmp.Length == lengthElements) ? tmp : new float[lengthElements];
            else
                buffer = new float[lengthElements];
        Marshal.Copy(inbuffer, buffer, 0, lengthElements);
        lock (obj.lockOb)
            obj.mFullBufferQueue.Enqueue(buffer);
        // Pass through to FMOD downstream (so monitoring still works)
        Marshal.Copy(buffer, 0, outbuffer, lengthElements);
        outchannels = inchannels;
        return FMOD.RESULT.OK;
    void OnDestroy()
        if (mObjHandle.IsAllocated)
            if (FMODUnity.RuntimeManager.CoreSystem.getMasterChannelGroup(out var masterCG) == FMOD.RESULT.OK && mCaptureDSP.hasHandle())
                masterCG.removeDSP(mCaptureDSP);
                mCaptureDSP.release();
            mObjHandle.Free();
        lock (lockOb)
            mFullBufferQueue.Clear();
            mEmptyBufferQueue.Clear();
    void OnAudioFilterRead(float[] data, int channels)
        // Avoid leftover noise
        Array.Clear(data, 0, data.Length);
        lock (lockOb)
            // Wait for a few captured blocks to avoid initial glitches/pops.
            if (mFullBufferQueue.Count > warmupBufferCount)
                int offset = 0;
                while (mFullBufferQueue.Count > 0 && offset < data.Length)
                    float[] front = mFullBufferQueue.Peek();
                    int remainingInFront = front.Length - mFrontBufferPosition;
                    if (remainingInFront <= 0)
                        mFullBufferQueue.Dequeue();
                        continue;
                    int remainingInData = data.Length - offset;
                    int copyLength = Math.Min(remainingInFront, remainingInData);
                    Array.Copy(front, mFrontBufferPosition, data, offset, copyLength);
                    mFrontBufferPosition += copyLength;
                    offset += copyLength;
                    // If buffer fully consumed, recycle it
                    if (mFrontBufferPosition >= front.Length)
                        // Recycle consumed buffers, limit to 32 stored
                        if (mEmptyBufferQueue.Count < 32)
                            mEmptyBufferQueue.Enqueue(front);
#endif
Unity recorder:
Also if I can help someone, we made this simple custom window (probably not that clean yet) to quickly add the ScriptUsageUnityRecorder & AudioListener in game when we want to record:
using System;
using System.IO;
using UnityEditor;
using UnityEditor.Presets;
using UnityEditor.Recorder;
using UnityEngine;
namespace Recording
    /// <summary>
    /// Usage: Create a preset from the Unity Recorder with the desired encoding settings (top left of Unity recorder's window).
    /// Name it MovieRecorderSettings.preset and save it anywhere.
    /// Open this window (Topbar->Tools) and start recording from there.
    /// The prepare button will add the AudioListener and the FMOD script needed to send the audio to the Unity Recorder.
    /// Starting and stopping the record are simply convenient ways to interact with the Unity Recorder from the same window.
    /// </summary>
    public class VideoRecorderWindow : EditorWindow
        RecorderController recorderController;
        public Preset preset;
        bool isPrepared;
        bool isRecording;
        public int take;
        const string OUTPUT_FOLDER = "Recordings";
        void OnInspectorUpdate()
            // Call Repaint on OnInspectorUpdate as it repaints the windows
            // less times as if it was OnGUI/Update
            Repaint();
        public void PrepareFMODRecorder()
            //Generate the FMOD Recorder helper obj
            GameObject helper = new GameObject("FMOD Recorder Helper", typeof(ScriptUsageUnityRecorder), typeof(AudioListener));
            // Find the preset asset named "MovieRecorderSettings" anywhere in the project and load it
            string[] guids = AssetDatabase.FindAssets("MovieRecorderSettings t:Preset");
            if (guids == null || guids.Length == 0)
                Debug.LogError("MovieRecorderSettings.preset not found in project assets.");
                return;
            string path = AssetDatabase.GUIDToAssetPath(guids[0]);
            preset = AssetDatabase.LoadAssetAtPath<Preset>(path);
            isPrepared = true;
            isRecording = false;
        public void StartRecorder()
            if (!isPrepared)
                return;
            // Create RecorderSettings from the provided Preset path.
            RecorderSettings recorderSettings = LoadRecorderSettingsFromPreset(preset);
            recorderSettings.FrameRate = 60;
            recorderSettings.Take = take;
            // Create a new RecorderControllerSettings to set the start and end frame for
            // the recording session and add the RecorderSettings to it.
            var controllerSettings = ScriptableObject.CreateInstance<RecorderControllerSettings>();
            controllerSettings.AddRecorderSettings(recorderSettings);
            controllerSettings.SetRecordModeToManual();
            // Create and setup a new RecorderController and start the recording.
            recorderController = new RecorderController(controllerSettings);
            recorderController.PrepareRecording();
            recorderController.StartRecording();
            isRecording = true;
        public void StopRecorder()
            if (!isRecording)
                return;
            recorderController.StopRecording();
            take++;
        static RecorderSettings LoadRecorderSettingsFromPreset(Preset _preset)
            // Create a new RecorderSettings instance and apply the Preset to it.
            RecorderSettings outSettings = (RecorderSettings)ScriptableObject.CreateInstance(typeof(MovieRecorderSettings));
            _preset.ApplyTo(outSettings);
            outSettings.name = _preset.name;
            return outSettings;
        void OpenRecordingsFolder(string folder)
            //Check if folder exists, try creating it otherwise
            if (!Directory.Exists(folder))
                try
                    Directory.CreateDirectory(folder);
                catch (Exception e)
                    Debug.LogError($"Failed to create folder {folder}: {e.Message}");
                    return;
            // Use Editor utility to reveal in OS file explorer
            EditorUtility.RevealInFinder(folder + "/");
        [MenuItem("Window/Custom/CustomVideoRecorder")]
        public static void ShowWindow()
            VideoRecorderWindow wnd = GetWindow<VideoRecorderWindow>();
            wnd.titleContent = new GUIContent("Custom Video Recorder");
        [Obsolete("Seems to crash sometimes/not work for recording when done in play mode")]
        private static void SetUnityAudio(bool value)
            const string AudioSettingsAssetPath = "ProjectSettings/AudioManager.asset";
            SerializedObject audioManager = new SerializedObject(UnityEditor.AssetDatabase.LoadAllAssetsAtPath(AudioSettingsAssetPath)[0]);
            SerializedProperty property = audioManager.FindProperty("m_DisableAudio");
            property.boolValue = !value;
            audioManager.ApplyModifiedProperties();
        private static bool GetUnityAudionEnabledState()
            return property.boolValue;
        void OnGUI()
            Color baseColor = GUI.color;
            var centered = new GUIStyle(EditorStyles.boldLabel) { alignment = TextAnchor.MiddleCenter };
            EditorGUILayout.Space(20);
            EditorGUILayout.LabelField("Video recorder", centered, GUILayout.ExpandWidth(true));
            if (GetUnityAudionEnabledState())
                GUI.color = Color.yellow;
                EditorGUILayout.LabelField("You must remove the option", centered, GUILayout.ExpandWidth(true));
                EditorGUILayout.LabelField("Project Settings - Audio - Disable Unity Audio", centered, GUILayout.ExpandWidth(true));
                isPrepared = false;
                GUI.color = baseColor;
                return;
                EditorGUILayout.LabelField("Game must be started", centered, GUILayout.ExpandWidth(true));
                isPrepared = false;
            else
                if (!isPrepared)
                    GUILayout.BeginHorizontal();
                    GUILayout.FlexibleSpace();
                    if (GUILayout.Button("Prepare Recording!", GUILayout.Width(180), GUILayout.Height(28)))
                        PrepareFMODRecorder();
                    GUILayout.EndHorizontal();
                else
                    EditorGUILayout.LabelField("All is well!", centered, GUILayout.ExpandWidth(true));
            EditorGUI.BeginDisabledGroup(!Application.isPlaying || !isPrepared || isRecording); // disable start when recording or not playing
            if (GUILayout.Button("Start Recording!", GUILayout.Width(180), GUILayout.Height(28)))
                StartRecorder();
            EditorGUI.EndDisabledGroup();
            EditorGUI.BeginDisabledGroup(!Application.isPlaying || !isPrepared || !isRecording); // disable stop when not recording or not playing
            if (GUILayout.Button("Stop Recording!", GUILayout.Width(180), GUILayout.Height(28)))
                StopRecorder();
            EditorGUILayout.LabelField($"Folder: {Application.dataPath}/{OUTPUT_FOLDER}", centered, GUILayout.ExpandWidth(true));
            // Open folder button
            GUILayout.Space(10);
            if (GUILayout.Button("Open Recordings Folder", GUILayout.Width(220)))
                OpenRecordingsFolder(Application.dataPath + "/../" + OUTPUT_FOLDER);
Thanks for the extra details, and for the helper script.
I haven’t been able to consistently reproduce the issue, but from what I can tell, it’s being caused by the number warmup buffers - I’ve been able to more consistently reproduce the delay when the warmup buffer count is larger. I’ve passed this along to the development team to look into further.
Idk why, but even following all the steps I’m still hearing double and still getting the output audio in the recording delayed for arround 1-2 seconds.
My Fmod studio integration version is 2.02.32 and unity is 6.3.10
Here’s my config:
Am I missing any step or config?
I made some changes in Yorsh script ‘cause I get an error in the CaptureDSPReadCallback method, because dsp_state.fuctions doesnt contain any getuserdata
Here is my code:
// Steps to use:
using System;
using UnityEngine;
#if UNITY_EDITOR
public class ScriptUsageUnityRecorder : MonoBehaviour
    void Start()
        int fmodSampleRate;
            enabled = false;
            return;
                else
            else
        else
        IntPtr userData;
        FMOD.DSP_STATE_FUNCTIONS functions = (FMOD.DSP_STATE_FUNCTIONS)Marshal.PtrToStructure(dsp_state.functions, typeof(FMOD.DSP_STATE_FUNCTIONS));
        functions.getuserdata(ref dsp_state, out userData);
        var obj = objHandle.Target as ScriptUsageUnityRecorder;
        if (inchannels > 2)
            inchannels = 2;
        float[] buffer;
        lock (obj.lockOb)
            else
        lock (obj.lockOb)
    void OnDestroy()
            mObjHandle.Free();
        lock (lockOb)
        lock (lockOb)
                int offset = 0;
                        continue;
#endif
Sorry for multiples replies, I’m new so only can include a media file for message
Hi!
What is your warmup buffer count set to? This issue is in large part a mislabeling issue, as the warmup buffer count is a pre-recording delay and will increase delay feeding audio to the Unity recorder to ensure a smooth start to the recorded audio, increasing latency as a result. I’d recommend lowering it to an acceptable value that doesn’t introduce any artifacting, and seeing whether that makes a difference.
For now, I can report that the example script has been flagged for improvements in a future release.
Hi there!
I tried to set it in 2 or 3, i didnt hear any artifact but still hearing the delay; by default is set in 50
Unfortunately, I haven’t been able to reproduce multiple seconds of delay using the settings and versions you posted. I’m only able to reproduce significant audio latency when the warmup buffer count is set to a larger number. Just to confirm, can I also get you to take a screenshot of the settings that the Unity Recorder is using?
I’m using the same settings of @Yorsh in the Unity recorder
Okay, so this has been an ongoing issue that doesn’t seem to be properly resolved. While multiple threads were opened for the same issue with different attempts of solutions, I think just work on small projects or specific scenarios.
But I’m honestly puzzled on how some users say that they managed to fix it when I think this comes from a core time mismatch between Unity’s engine and FMOD’s engine.
(?) I think the users that fixed it just are recording with a good PC + low FPS/resolution so that the actual game time while recording is not significantly delayed from the final output (?)
As of now, I see two different (public made) attempts to tackle this:
  1. (Scripting Example) Capture FMOD’s final audio output through a custom DSP, stores it in buffered queues, and feeds it into Unity’s OnAudioFilterRead callback so Unity Recorder can record FMOD audio like native Unity audio. This one requires FMOD 2.0.13
  2. (User-made solution) Record FMOD’s final audio output through a custom DSP attached to the master bus, stores the captured audio samples in memory, and saves them directly into a separate.wav audio file. Some other users also integrated with FFmpeg to add the audio to the recorded video and overwrite it.
None of these solutions truly solve the fundamental synchronization problem between FMOD and Unity. Especially because the audio is not “just delayed by a few seconds” the gameplay plays a certain speed and while FMOD events are invoked at a slower one (the speed you speed you see while playing with recording on). To tackle this issue on a video Editor you would need to speed up the audio, but this creates pitch shifting and artifacts.
A possible solution would be to record all FMOD event calls, parameter changes, and playback timestamps during gameplay capture, then after the video recording is finished, replay those events in a separate empty scene at the exact recorded timing to render the audio independently into a final synchronized track.
I’ve wanted to try this solution for a while now but never had time to do this before but this ongoing issue needs to be resolved one way or another, as it is quite frustrating.
I recently tried to use the provided ScriptUsageUnityRecorder to get recorder working with FMOD audio and did also encounter large audio delays myself – though figured out the issue in my case.
If I have Unity’s recorder set to constant instead of variable framerate for capture, and am attempting to capture a video with settings which I can not locally run in real time, then the issue occurs. I could switch to variable and the audio would sync up okay. At constant, where unity might take longer to render the frame than the time passed during the frame delta, the audio desync happens.
I suspect this is because FMOD’s threads run with their own time that are not powered off the Unity game time and can not run at lower than real time speeds?
After spending too long tinkering trying to figure things out – once I realized this and I am at least able to capture in sync at variable, but if I want constant frame rate I need to capture on a machine powerful enough to keep up in real time.
Here is an updated version that syncs with unity update and works well with variable/const framerate of Unity Recorder. One thing: you need to set Project Settings/Audio/Disable Unity Audio = false before entering playmode. Create GameObject with this component in runtime. Another catch is that might be crashes, relaunch Unity will help. This is the most stable what i managed to get.
Here is the script:
using System;
using System.Threading;
using Sirenix.OdinInspector;
using UnityEngine;
namespace _Project.Recorder
    internal sealed class FmodAudioRecorderDSP : MonoBehaviour
        [Title("Diagnostics")]
        [Tooltip("Print capture stats and mixer mode changes to the console. Errors are reported regardless")]
        [SerializeField] private bool showLogs;
        [Tooltip("Log a stats line every N seconds while capturing. 0 - only the final summary")]
        [SerializeField] [MinValue(0f)] [ShowIf(nameof(showLogs))] private float statsLogInterval = 5f;
        [Title("Non-realtime capture")]
        [Tooltip("Switch FMOD to NOSOUND_NRT and advance its mixer by hand, one video frame worth of audio per rendered frame. " +
                 "FMOD goes silent while this is on - that is the point of offline rendering")]
        [SerializeField] private bool driveMixerManually = true;
        [Tooltip("Stay this many audio frames ahead of the video timeline so Unity never pulls an empty queue")]
        [SerializeField] [MinValue(0)] private int aheadFrames = 1024;
        [Tooltip("Safety cap on CoreSystem.update() calls per rendered frame")]
        [SerializeField] [MinValue(1)] private int maxPumpsPerFrame = 64;
        private readonly Queue<float[]> mFullBufferQueue = new();
        private readonly Queue<float[]> mEmptyBufferQueue = new();
        private static int nbChannelDetected = 0;
        // Stats counters. Written from the FMOD mixer thread and from Unity's audio thread,
        // read on the main thread - every access goes through Interlocked, and nothing here logs.
        private long mProducedFrames;
        private long mConsumedFrames;
        private long mDeliveredFrames;
        private long mFmodCallbacks;
        private long mFilterReads;
        // Main thread only.
        private int mSampleRate;
        private int mRenderedFrames;
        private int mCaptureFrames;
        private double mTimelineFrames;
        private float mRealStartTime;
        private float mNextStatsLogTime;
        // Manual mixer pumping, main thread only.
        private FMOD.OUTPUTTYPE mPreviousOutput;
        private bool mOutputSwitched;
        private long mPumpCalls;
        private int mPumpCapHits;
        // Start, not OnEnable: to buffer between object creation and dsp start
        private void Start()
            StartDSP();
        private void OnDisable()
            StopDSP();
        private void StartDSP()
            ResetStats();
            int unityChannels = config.speakerMode == AudioSpeakerMode.Stereo ? 2 : (int) config.speakerMode;
            int fmodSampleRate;
                enabled = false;
                return;
            mSampleRate = unitySampleRate;
            // Switch the output before the tap is attached: setOutput tears the output down and brings it back up.
            EnterNonRealtimeMode();
                userdata = GCHandle.ToIntPtr(mObjHandle),
                        // channelmask устарел, FMOD его игнорирует и пишет об этом в консоль
                        mCaptureDSP.setChannelFormat(0, 2, FMOD.SPEAKERMODE.STEREO);
                    else
                else
            else
        private void StopDSP()
            LogStats("final");
            // Detach first, free the handle second. A live DSP whose userdata points at a freed
            // GCHandle is a hard crash on the next mixer callback, so the tap must go down
            // even when the master channel group cannot be reached.
            if (mCaptureDSP.hasHandle())
                else
                    Debug.LogError("FMOD: master channel group is unreachable, releasing the capture DSP anyway.");
                mCaptureDSP = default;
            if (mObjHandle.IsAllocated) mObjHandle.Free();
            ExitNonRealtimeMode();
            lock (lockOb)
        #region Manual mixer pumping
        private void EnterNonRealtimeMode()
            if (!driveMixerManually) return;
            var core = FMODUnity.RuntimeManager.CoreSystem;
            var result = core.getOutput(out mPreviousOutput);
            if (result != FMOD.RESULT.OK)
                Debug.LogError($"FMOD: getOutput failed ({result}). Staying realtime - capture will drift on constant frame rate.");
                return;
            result = core.setOutput(FMOD.OUTPUTTYPE.NOSOUND_NRT);
                Debug.LogError($"FMOD: setOutput(NOSOUND_NRT) failed ({result}). Staying realtime - capture will drift on constant frame rate.");
                return;
            mOutputSwitched = true;
            if (showLogs) Debug.Log($"FMOD: mixer is driven manually, output {mPreviousOutput} -> NOSOUND_NRT.");
        private void ExitNonRealtimeMode()
            if (!mOutputSwitched) return;
            mOutputSwitched = false;
            var result = FMODUnity.RuntimeManager.CoreSystem.setOutput(mPreviousOutput);
                Debug.LogError($"FMOD: failed to restore output {mPreviousOutput} ({result}). " +
                               "Sound will stay silent until Play Mode is restarted.");
                return;
            if (showLogs) Debug.Log($"FMOD: mixer is back on its own clock, output NOSOUND_NRT -> {mPreviousOutput}.");
        // Runs after game logic has posted this frame's events, so the mixer renders what the frame actually asked for.
        private void LateUpdate()
            if (mSampleRate <= 0) return;
            long target = (long) mTimelineFrames + aheadFrames;
            int pumps = 0;
            while (Interlocked.Read(ref mProducedFrames) < target && pumps < maxPumpsPerFrame)
                if (core.update() != FMOD.RESULT.OK) break;
                pumps++;
            mPumpCalls += pumps;
            if (pumps >= maxPumpsPerFrame) mPumpCapHits++;
        #endregion
        private void OnAudioFilterRead(float[] data, int channels)
            // Audio thread: count only, never log.
            Interlocked.Increment(ref mFilterReads);
            Interlocked.Add(ref mConsumedFrames, channels > 0 ? data.Length / channels : 0);
            lock (lockOb)
                int offset = 0;
                        continue;
                    if (mFrontBufferPosition < front.Length) continue;
                    if (mEmptyBufferQueue.Count < 32) mEmptyBufferQueue.Enqueue(front);
                Interlocked.Add(ref mDeliveredFrames, channels > 0 ? offset / channels : 0);
        private static FMOD.RESULT CaptureDSPReadCallback(ref FMOD.DSP_STATE dsp_state, IntPtr inbuffer, IntPtr outbuffer, uint length, int inchannels, ref int outchannels)
            IntPtr userData;
            dsp_state.functions.getuserdata(ref dsp_state, out userData);
            var obj = objHandle.Target as FmodAudioRecorderDSP;
            if (inchannels > 2)
                inchannels = 2;
            // FMOD mixer thread: count only, never log.
            Interlocked.Increment(ref obj.mFmodCallbacks);
            Interlocked.Add(ref obj.mProducedFrames, length);
            int lengthElements = (int) length * inchannels;
            float[] buffer;
            lock (obj.lockOb)
                    float[] tmp = obj.mEmptyBufferQueue.Dequeue();
                    buffer = tmp.Length == lengthElements ? tmp : new float[lengthElements];
                else
            lock (obj.lockOb)
        #region Stats
        private void Update()
            mRenderedFrames++;
            // The video timeline: a rendered frame is worth exactly one frame delta of audio.
            float delta = Time.captureDeltaTime;
            if (delta > 0f) mCaptureFrames++;
            else delta = Time.unscaledDeltaTime;
            mTimelineFrames += (double) delta * mSampleRate;
            if (statsLogInterval <= 0f) return;
            if (Time.realtimeSinceStartup < mNextStatsLogTime) return;
            mNextStatsLogTime = Time.realtimeSinceStartup + statsLogInterval;
            LogStats("progress");
        // Explicit request, so it prints even with showLogs off.
        [Button("Log stats now")]
        private void LogStatsNow()
            LogStats("manual", force: true);
        private void ResetStats()
            Interlocked.Exchange(ref mProducedFrames, 0L);
            Interlocked.Exchange(ref mConsumedFrames, 0L);
            Interlocked.Exchange(ref mDeliveredFrames, 0L);
            Interlocked.Exchange(ref mFmodCallbacks, 0L);
            Interlocked.Exchange(ref mFilterReads, 0L);
            mRenderedFrames = 0;
            mCaptureFrames = 0;
            mTimelineFrames = 0d;
            mPumpCalls = 0L;
            mPumpCapHits = 0;
            mRealStartTime = Time.realtimeSinceStartup;
        // Main thread only - the mixer and audio threads never log, they only bump counters.
        private void LogStats(string title, bool force = false)
            if (!showLogs && !force) return;
            if (Interlocked.Read(ref mFmodCallbacks) == 0L && Interlocked.Read(ref mFilterReads) == 0L) return;
            Debug.Log(BuildStatsReport(title));
        private string BuildStatsReport(string title)
            long produced = Interlocked.Read(ref mProducedFrames);
            long consumed = Interlocked.Read(ref mConsumedFrames);
            long delivered = Interlocked.Read(ref mDeliveredFrames);
            long fmodCallbacks = Interlocked.Read(ref mFmodCallbacks);
            long filterReads = Interlocked.Read(ref mFilterReads);
            long expected = (long) mTimelineFrames;
            float timelineElapsed = FramesToSeconds(expected);
            float realElapsed = Time.realtimeSinceStartup - mRealStartTime;
            float clockRatio = timelineElapsed > 0f ? realElapsed / timelineElapsed : 0f;
            float captureDelta = Time.captureDeltaTime;
            string frameRateMode = captureDelta > 0f ? $"{1f / captureDelta:F1} fps, constant" : "variable frame rate";
            string mixerMode = mOutputSwitched ? "NOSOUND_NRT, driven by hand" : "realtime, own clock";
            int queuedBuffers;
            lock (lockOb) queuedBuffers = mFullBufferQueue.Count;
            return $"[FmodAudioRecorderDSP] stats ({title})\n" +
                   $"  render    : {mRenderedFrames} frames ({mCaptureFrames} captured), captureDeltaTime {captureDelta:F5}s ({frameRateMode})\n" +
                   $"  clock     : timeline {timelineElapsed:F2}s, real {realElapsed:F2}s, real/timeline {clockRatio:F2}\n" +
                   $"  mixer     : {mixerMode}, {mPumpCalls} pumps, {PumpsPerFrame():F2} per rendered frame, cap hits {mPumpCapHits}\n" +
                   $"  produced  : {produced} frames / {FramesToSeconds(produced):F2}s (FMOD mixer, {fmodCallbacks} callbacks)\n" +
                   $"  consumed  : {consumed} frames / {FramesToSeconds(consumed):F2}s (Unity pulled, {filterReads} reads)\n" +
                   $"  delivered : {delivered} frames / {FramesToSeconds(delivered):F2}s, underrun {consumed - delivered} frames\n" +
                   $"  expected  : {expected} frames / {timelineElapsed:F2}s (video timeline x {mSampleRate}Hz)\n" +
                   $"  drift     : produced-expected {produced - expected} frames / {FramesToSeconds(produced - expected):F2}s\n" +
                   $"  backlog   : {produced - delivered} frames / {FramesToSeconds(produced - delivered):F2}s, queue {queuedBuffers} buffers";
        private float FramesToSeconds(long frames)
            return mSampleRate > 0 ? frames / (float) mSampleRate : 0f;
        private float PumpsPerFrame()
            return mRenderedFrames > 0 ? mPumpCalls / (float) mRenderedFrames : 0f;
        #endregion
