VisualStudio isnt recognising Fmod
Hello. Im trying to make a custom BP node in C++ that’s using the Fmod API, but its giving errors for every Fmod header “Canot open source file FMODAudioComponent.h”. I have added “FMODStudio” in MyProject.Build.cs, but that changes noting.
I followed this tutorial for Fmod integration in to UE5 https://www.youtube.com/watch?v=w_cjlfkEnVQ&ab_channel=EloyDeCort-GameAudio
Please add it to the PrivateDependencyModulesNames:
public class MyProject : ModuleRules
	public MyProject(ReadOnlyTargetRules Target) : base(Target)
		PCHUsage = PCHUsageMode.UseExplicitOrSharedPCHs;
		PublicDependencyModuleNames.AddRange(new string[] { "Core", "CoreUObject", "Engine", "InputCore", "EnhancedInput" });
		PrivateDependencyModuleNames.AddRange(new string[] { "FMODStudio" });
More information about programming in UE with FMOD can be found here: Unreal Integration | User Guide - Programming Support
I did it and regenerated the visual studio project files. And it changed nothing
After more tinkering, I found that the Fmod headers work when I use them in any class I make in C++ Classes folder. Previously I was trying to make this work in a custom BP library plugin. I guess when making custom plugins it doesn’t get the directories from other plugins.
Thanks for sharing the solution
