^^ you should be able to download fmod ex via the download page now.
Hi @brett
I am also porting old project that is using FMOD Ex.
Can I please get access to the FMOD Ex libraries?
hi pavlest i have given you access
Hi @brett
I’m working on a port that uses FMOD Ex 4.44.15. Could I get access to the libraries, please?
Thanks very much
Hi Kurt, I have added permission for you, it should be in the download page.
That’s excellent. Thanks Brett
Hi Roson I have added access for you.
Hi brett, Thanks.
Need it for a old project as well.
i have added you
I would also need it for an old project
Hi, I have added it for you.
Hi Franou I have enabled access for you.
Hi, I need some tools for working with an older game only available in the older FMOD 4 API. Fairly sure that 4.44.64 (which is afaik the latest? correct me if I’m wrong) should work.
^ I have enabled access
Thank you so much!
Hi, I want to update fmodex.dll of an old game. Can I also have access to it? Thank you so much.
