Hi Aaron,
I’ve made FMODex 4.32.06 available on the downloads page.
Cheers,
Morgan
Thanks again! just want to check if there’s also that version (4.32.6) for FMODex Designer as well, there’s a very close version so I’m not sure how much the version difference of what’s already available will matter, but I’m just trying to cover my bases lol
No problem! I’m not exactly sure what the compatibility situation is between point releases of FMODex either, so I’ve made FMOD Designer 4.32.06 available on the downloads page just in case.
Cheers,
Morgan
hi guys i am wondering if i can access FMODEx? because i am in need to work on this for my project.
Access granted.
May I ask where I can download 32-bit: fmodex.dll, fmod_event.dll, fmod_event_net.dll, version is 4.44.64
I’m working on a port that uses FMOD Ex 4.06.00. Could I get access to the libraries, please?
Thanks very much
it’s perfect, thank you very much. Best regards
JU
Hi.
Where can I find a pre-built FmodEx?
I have looked everywhere, but nothing so far.
Access granted. Try the Download page again.
I need to find fmodex_vc.lib to help out with an open source game, is that something that exists?
I’ve granted you access to the FMOD Ex Downloads.
Hi @Andrew
I am also looking to download fmodex API for a old game project which using fmod ex api(version: 0x00044449) on Android and Windows. May I get access to the libraries?
Thank you.
Best regards.
Allen
I’ve granted you access to FMOD Ex Downloads. Unfortunately I couldn’t find 4.44.49 so I put up 4.44.48 and 4.44.50. Hope that’s good enough for you.
I also need access to fmodex API for a project.
Access granted.
Hello, I am looking to build some software from a few years ago as well, and it depends on older FMOD Ex binaries, particularly 4.29.02, 32-bit and 64-bit. Could I have access as well? Thank you.
Access granted.
