Which functions return FMOD_ERR_NOTREADY when in FMOD_OPENSTATE_SETPOSITION?
The documentation for Channel::setPosition states;
https://www.fmod.com/resources/documentation-api?version=2.0&page=core-api-channel.html#channel_setposition
If playing a Sound created with System::createStream or FMOD_CREATESTREAM changing the position may cause a slow reflush operation while the file seek and decode occurs. You can avoid this by creating the stream with FMOD_NONBLOCKING. This will cause the stream to go into FMOD_OPENSTATE_SETPOSITION state Sound::getOpenState and Sound commands will return FMOD_ERR_NOTREADY. Channel::getPosition will also not update until this non-blocking set position operation has completed.
Which functions will return FMOD_ERR_NOTREADY when the sound is in FMOD_OPENSTATE_SETPOSITION?
What is the definition of a “Sound command”?
All functions in the FMOD::Sound class.
https://www.fmod.com/resources/documentation-api?version=2.0&page=core-api-sound.html
A few functions may not be affected because their data is cached/not affected by position change, such as Sound::getName for example.
