Accessibility For Blind Designers
I am a visually impaired sound designer and very interested in using FMOD.
I am hoping that there is some kind of accessibility option to help me navigate the software using Mac VoiceOver.
I searched this forum and the only mention of this issue was posted back in 2008. This issue was never addressed by FMOD support or community members.
I use ProTools and Reaper seemlessly with a screen reader and macro scripts created specifically for both programs and I am sure it is not impossible to apply something similar to FMOD.
As digital audio technology progresses it is important to include blind and visually impaired people in the process. I would love to be able to use this software but without this kind of accommodation I cannot.
If there is something that I am missing in regards to my inquiry please point me in the right direction. If this is something that has gone un addressed then I must request that we find a solution. I can’t see but my ideas in sound are abundant. There is no reason for the field of sound design to be populated only by the sighted.
Thank you for the support on this subject.
Andy
www.thisisandyslater.net
I
Hi Andy, thank you for getting in touch regarding this important issue. We really appreciate your enthusiasm!
We will schedule some time to investigate better accessibility options. In the meantime, given we don’t have a lot of experience in this area, it would be good to learn about your workflow with other software:
  1. Do you use screen readers to interact with the individual graphical items on screen? What is your approach to dragging and dropping of items (regions/clips) on the timeline? What is your approach for editing values on dials/faders for DSP effects?
  2. Are the ProTools and Reaper scripts officially provided or user created? Can you link to these?
  3. Have you tried our scripting interface before? While this may be less intuitive as it requires use of Javascript, it does allow full access to our project data model, and supports most playback operations.
Thanks again!
Hi @patrick,
I too am blind, and am interested in the possibility of composing for video games.
It looks like Andy didn’t respond to your questions.
I’ll attempt some responses to give you a better understanding of how we go about using screen readers.
The first rule is that we should be considered keyboard ninjas. That is to say that any implementation of keyboard commands, shortcuts ETC. is very much appreciated.
though we do have some control over the mouse pointer with our screen readers, it is rudimentary at best, and quite frustrating when we have to rely on it.
When working in reaper we use a deeply integrated extension called OSARA. https://osara.reaperaccessibility.com/
though it was not developed by Cockos, it is fully supported and the OSARA devs have high level contact with Cockos.
OSARA makes extensive use of the keyboard shortcuts facilities in Reaper, as well as the SWS extension.
We navigate the interface using keystrokes and keyboard shortcuts, as well as menu diving. OSARA provides spoken feedback by passing info from Reaper to our screen readers.
When working with the timeline, for example, I select my track by arrowing up and down until I hear the one I need spoken by my screen reader. then, Assuming there is something on the track, I press ctrl/right arrow to select the item I need to interact with. If I want to move it, I press ctrl/x, I press ctrl/j to jump to a point on the timeline, and ctrl/v to paste my item.
If I need to split the item, I either play until I get to the split point, or scrub by tapping right/left arrows to find the place I need. I press “s” to split.
Almost every operation is available via a shortcut or menu item, and when feedback is needed OSARA is able to pass the feedback on to the screen reader. About the only thing I can’t do is look at a spectragram or routing diagram.
For adjusting values in plugins and the like we rely on midi implementation in the plugins. If a parameter is exposed to be controlled via midi, then OSARA has a parameters dialog where we can tweak thee parameter through use of direct entry of values or moving sliders up and down with arrows or pgup/pgdn.
When midi implementation is not provided for a parameter or control, sometimes we are able to get by with an OCR solution which allows to click on the screen with mouse commands. This isn’t ideal though.
I hope this is helpful.
As a starting point for accessibility i would suggest that you implement as much keyboard control as possible.
I’m just learning about the existence and use of middlewear but I hope that when I’m ready, that I can take advantage of FMOD to create some amazing game scores.
Thanks for reading! :slight_smile: Rusty
Thanks for your feedback, it’s a very interesting perspective on how software is used by the blind. I agree that keyboard shortcuts are the best place to start ensuring we have good coverage of the features. I think one of the biggest issues is our lack of selection model, the ability to use direction keys / tab to navigate around the interface, switch tracks etc.
Hi @Mathew,
thanks for responding.
Yeah, that would put a damper on things. :slight_smile:
I know virtually nothing about development, so I have no idea how
difficult it would be to implement such a selection model so that one
could navigate with arrows and tab.
I have a blind friend who is currently working on an addon for NVDA a
commonly used screen reader which may create some level of
accessibility for FMOD.
And I thought I was learning about how to compose for videogames! :slight_smile:
I am a Senior Lecturer at pointblank music school. We use FMOD (with Unity) to introduce students to non-linear and interactive audio, and I am a big fan of your software. FMOD is by far the best solution for budding music producers and sound designers as a gateway into the world of game audio, due to its comprehensive interface. As the Module Leader for Audio for Games, I have an upcoming challenge in supporting a student through this process, who happens to be blind.
I have read all of the threads posted by people asking for more accessibility for blind users, noting that the last such thread dates back to 2021. First of all, has there been any progress in this regard?
In terms of my own student, they have just started the 3 year BA, so we have two years to prepare for their progress into the Audio for Games module. Might you be able to assist in developing better tools for visually impaired students within that timeframe? I note that Wwise added accessibility features in 2021, following the request of a similar educational institution.
I look forward to your response, and I am very happy to assist in any way that I can. If would rather take this discussion out of the domain of a public forum, please email me at rory.walker(at)pointblankmusicschool.com
Kind regards,
Rory
Since FMOD Studio’s initial release, we have made several minor improvements that might be relevant:
  • We have improved the contrast of FMOD Studio’s default colour scheme.
  • We have added support for pixel scaling, allowing users to make the interface larger. (To change FMOD Studio’s pixel scale factor, select “Edit > Preferences…” to open the preferences dialog, navigate to the “Interface” tab, then change the “Force device pixel scale factor to [value]” property.)
  • We have also added support for scripts that control FMOD Studio and/or make changes to projects. While the ability to create scripts is not an accessibility feature in itself, it can potentially be used to make existing features controllable using only keyboard shortcuts, or to create alternative interfaces for controlling existing features.
However, there is still much more that we need to do. As of the time of writing (February of 2026) we have plans to:
  • Add support for screen-reader software.
  • Add support for customizing the colours used by FMOD Studio’s interface, as well as colour schemes designed for common forms of colour blindness.
  • Add keyboard shortcuts to support navigating and controlling FMOD Studio without a mouse.
We are unable to provide accurate estimates as to when specific features will be released, as our agile development model requires us to be able to alter the planned scope and schedule of development sprints at any time.
I can tell you that the three features I mentioned are currently in our backlog of planned features, but have not yet been scheduled for development or assigned to specific developers.
I’ll add you to the list of people who’ve requested these features.
Hello Joseph and Rory,
I am a blind sound designer and media artist.
I would love to see FMODB screen reader compatible both on Mac and windows as well as being navigable without the reliance on a mouse or GUI.
I believe I was one of the original posters five or so years ago asking for accessibility and I’m very happy to see that it’s picking up now.
I’m glad to see that access is in development for FMOD and I would like to offer support for not only testing but also in the development process.
Please let me know how I can help and get involved.
Take care,
Andy
Andy Slater
Thank you for a very clear and comprehensive response. I will test out some screen-readers and see how they fair.
We’re definitely interested in hearing your ideas on how we could improve FMOD Studio to better suit your needs, and about your experiences of what has and hasn’t worked with other software. Any insight you can give us will be a big help.
