AHDSR probem on volume with Loop region and release
Hello everyone,
I’m a newbie here and I have two problems with using AHDSR modulation on the volume of a single instrument. The first problem happens each time that it loops (loop region), the AHDSR modulator gets triggered again. Is this normal and it there a way to get around this? The second problem happens on release, jumping to a new region with a parameter. The AHDSR doesn’t seem to play the release but stops playing (cuts off).
I’m pn a MacBook Pro running OS 10.13.3 and Fmod Studio 1.10.04, 64-bit, Build#93853
Thank you so much for all feedback.
Cheers
Jef
You can solve both of your problems by setting the instrument to asynchonous mode. To do this, select the instrument, and click on the “Async” toggle button in the deck.
The reason why the AHDSR modulator’s attack period plays when the playback position loops is that repositioning the playback position on synchronous instrument retriggers that instrument. (This behavior is only rarely noticed, as it is only obvious in a rare few circumstances, such as yours.) Synchronous instruments are not retriggered when the playback position is repositioned unless the playback position leaves and re-enters the instrument’s trigger region.
The reason why a synchronous instrument immediately falls silent when the playback position is moved off its trigger region is that synchronous instruments always play the part of the waveform currently under the playback position. When the playback position moves to a position that’s not over any part of the waveform, there is no waveform to play, and so the instrument immediately stops producing output. Asynchronous instruments do not have this behavior, and so will play out to completion (or until their AHDSR modulator release tails have finished, if subject to AHDSR modulation).
Note that setting an instrument to asynchronous mode means you will no longer be able to seek within the audio files associated with that instrument simply by repositioning the playback position. It is still possible to seek within the assets by automating the instrument’s start offset property, but this can be a somewhat fiddly process.
Thank you so much for the quick and thorough reply Joseph!
Hi there! I have been fighting against this same problem for hours and finally found a solution.
In my case I needed the 6 tracks inside the main music event to run in sync and loop, but fade in or out depending on a discrete parameter value. Since AHDSR in clips nor tracks was working the way I needed, I created one send channel in the mixer window for each track (6 in total), assigned those tracks (pre-fader) to the sends (-inf volum in the event page), [1]
And created a snapshot for each layer combination I needed. Then added AHDSR mod to the Intensity knob of each snap (this way you can control attack and release time). [2]
In a parameter sheet (discrete), made a snapshot instrument for each snapshot and put them in the desired value and… VOILÀ! Working exactly as I needed. [3]
