Audio Output Plugin Android
I tried to register ayudio output with registerOutput method but i keep getting error FMOD_ERR_PLUGIN_VERSION, fmod version 2.02.14, compileSdkVersion 33
    unsigned int outputhandle;
    FMOD_OUTPUT_DESCRIPTION outputDesc;
    outputDesc.apiversion = FMOD_VERSION;
    outputDesc.name = "My Output";
    outputDesc.version = 0x00010000;
    outputDesc.getnumdrivers = GetNumDrivers;
    outputDesc.getdriverinfo = GetDriverInfo;
    outputDesc.init = OutputInit;
    outputDesc.start = OutputStart;
    outputDesc.stop = OutputStop;
    outputDesc.close = OutputClose;
    outputDesc.update = OutputUpdate;
    outputDesc.gethandle = OutputGetHandle;
    LOGE("fmod::EchoesSpatEngine: %s\n", "registerOutput");
    result = fmodsystem->registerOutput(&outputDesc, &outputhandle);
    if (result != FMOD_OK) {
        LOGE("fmod:: Could not set output because: %s\n", FMOD_ErrorString(result));
Maybe I have missed something in the FMOD_OUTPUT_DESCRIPTION implementation? Or should the output logging be in some special place?
I will link to the FMOD_OUTPUT_DESCRIPTION documentation which lists all its variables and their requirements: FMOD API | Plugin API Reference - Output.
In this situation, you are just missing
// Should be
outputDesc.apiversion = FMOD_OUTPUT_PLUGIN_VERSION;
HI Connor_FMOD
Thanks for the answer. I fixed it and now everything works
