Err_output_init
Hey i’ve run into a roadblock trying to get FMOD Core API to work on Linux Ubunutu 24.04.
I’ve got everything working on Windows and it seems like the lib files are working on Linux aswell since I get the logs from FMOD.
[LOG] SystemI::init                            : Initialize version=20307 (150747), maxchannels=512, flags=0x00020000
[LOG] FMOD_PulseAudio_CheckOutputSupport       : PulseAudioScope::pa_context_connect returned -1.
[LOG] SystemI::setOutputInternal               : Setting output to 'FMOD ALSA Output'
[LOG] OutputALSA::registerLib                  : Loaded ALSA version 1.2.11.
[LOG] OutputALSA::enumerate                    : Found device NAME:null IOID:(null).
[LOG] OutputALSA::enumerate                    : Found device NAME:sysdefault IOID:(null).
[LOG] OutputALSA::enumerate                    : Found device NAME:iec958 IOID:(null).
[LOG] OutputALSA::enumerate                    : Found device NAME:pipewire IOID:(null).
[LOG] OutputALSA::enumerate                    : Found device NAME:default IOID:(null).
[LOG] OutputALSA::enumerate                    : Found device NAME:hw:CARD=I82801AAICH,DEV=0 IOID:(null).
[LOG] OutputALSA::enumerate                    : Found device NAME:hw:CARD=I82801AAICH,DEV=1 IOID:Input.
[LOG] OutputALSA::enumerate                    : Found device NAME:plughw:CARD=I82801AAICH,DEV=0 IOID:(null).
[LOG] OutputALSA::enumerate                    : Found device NAME:plughw:CARD=I82801AAICH,DEV=1 IOID:Input.
[LOG] OutputALSA::enumerate                    : Found device NAME:sysdefault:CARD=I82801AAICH IOID:(null).
[LOG] OutputALSA::enumerate                    : Found device NAME:front:CARD=I82801AAICH,DEV=0 IOID:(null).
[LOG] OutputALSA::enumerate                    : Found device NAME:surround21:CARD=I82801AAICH,DEV=0 IOID:Output.
[LOG] OutputALSA::enumerate                    : Found device NAME:surround40:CARD=I82801AAICH,DEV=0 IOID:Output.
[LOG] OutputALSA::enumerate                    : Found device NAME:surround41:CARD=I82801AAICH,DEV=0 IOID:Output.
[LOG] OutputALSA::enumerate                    : Found device NAME:surround50:CARD=I82801AAICH,DEV=0 IOID:Output.
[LOG] OutputALSA::enumerate                    : Found device NAME:surround51:CARD=I82801AAICH,DEV=0 IOID:Output.
[LOG] OutputALSA::enumerate                    : Found device NAME:iec958:CARD=I82801AAICH,DEV=0 IOID:Output.
[LOG] OutputALSA::enumerate                    : Found device NAME:dmix:CARD=I82801AAICH,DEV=0 IOID:Output.
[LOG] OutputALSA::enumerate                    : Found device NAME:dsnoop:CARD=I82801AAICH,DEV=0 IOID:Input.
[LOG] OutputALSA::enumerate                    : Found device NAME:dsnoop:CARD=I82801AAICH,DEV=1 IOID:Input.
[ERR] OutputALSA::init                         : snd_pcm_open returned -112 = Host is down.
[LOG] SystemI::closeInternal                   : Closed.
Currently running FMOD Engine 2.03.07
Error -112 for snd_pcm_open indicates that the host is down, so there’s likely an issue with your default audio device, or with ALSA itself. I’d recommend making sure that your device is set to be the default and is functioning as expected (is it working for other applications?), and to make sure the libasound2-dev and any other ALSA packages are updated and verified. You may also wish to try installing pulseaudio as an alternative to ALSA and seeing whether that works without any issues.
Besides that, what settings is your output device set to use? i.e. channel count/format, sample rate, bit depth, etc.
Trying it with pulseaudio gives me these errors instead.
[LOG] OutputALSA::enumerate                    : Found device NAME:lavrate IOID:(null).
[LOG] OutputALSA::enumerate                    : Found device NAME:samplerate IOID:(null).
[LOG] OutputALSA::enumerate                    : Found device NAME:speexrate IOID:(null).
[LOG] OutputALSA::enumerate                    : Found device NAME:jack IOID:(null).
[LOG] OutputALSA::enumerate                    : Found device NAME:oss IOID:(null).
[LOG] OutputALSA::enumerate                    : Found device NAME:pulse IOID:(null).
[LOG] OutputALSA::enumerate                    : Found device NAME:speex IOID:(null).
[LOG] OutputALSA::enumerate                    : Found device NAME:upmix IOID:(null).
[LOG] OutputALSA::enumerate                    : Found device NAME:vdownmix IOID:(null).
[LOG] OutputALSA::enumerate                    : Found device NAME:default:CARD=I82801AAICH IOID:(null).
[LOG] OutputALSA::enumerate                    : Found device NAME:usbstream:CARD=I82801AAICH IOID:(null).
[LOG] OutputALSA::init                         : Requested period size: 1024, Actual period size: 1024
[LOG] OutputALSA::init                         : Requested ALSA buffer size: 4096, Actual ALSA buffer size: 4096
[LOG] Thread::initThread                       : Init FMOD stream thread. Affinity: 0x4000000000000003, Priority: 0xFFFF7FFB, Stack Size: 98304, Semaphore: No, Sleep Time: 10, Looping: Yes.
[LOG] SystemI::DSPCodecPoolRegister            : register codec pool for pool type 0
[LOG] Thread::initThread                       : Init FMOD mixer thread. Affinity: 0x4000000000000001, Priority: 0xFFFF7FFA, Stack Size: 81920, Semaphore: No, Sleep Time: 0, Looping: Yes.
[LOG] SystemI::createSoundInternal             : Create name='Content/Audio/Music/cabin.ogg', mode=0x00000080
[LOG] SystemI::createSoundInternal             : exinfo->cbsize             = 224
[LOG] SystemI::createSoundInternal             : Stream: name='(null)', format=2, channels=2, frequency=44100, lengthbytes=2232567, lengthpcm=5603294, pcmblocksize=0, loopstart=0, loopend=0, mode=0x00000000, channelmask=0x00000000, channelorder=0, peakvolume=0.000000.
[LOG] Thread::initThread                       : Init FMOD file thread. Affinity: 0x4000000000000003, Priority: 0xFFFF7FFC, Stack Size: 65536, Semaphore: No, Sleep Time: 10, Looping: Yes.
[LOG] SystemI::createSoundInternal             : Create name='Content/Audio/Music/cave.ogg', mode=0x00000080
[LOG] SystemI::createSoundInternal             : Stream: name='(null)', format=2, channels=2, frequency=44100, lengthbytes=2647809, lengthpcm=8342682, pcmblocksize=0, loopstart=0, loopend=0, mode=0x00000000, channelmask=0x00000000, channelorder=0, peakvolume=0.000000.
[LOG] SystemI::createSoundInternal             : Create name='Content/Audio/Music/dimension.ogg', mode=0x00000080
[LOG] SystemI::createSoundInternal             : Stream: name='(null)', format=2, channels=2, frequency=44100, lengthbytes=2226660, lengthpcm=5556600, pcmblocksize=0, loopstart=0, loopend=0, mode=0x00000000, channelmask=0x00000000, channelorder=0, peakvolume=0.000000.
[LOG] SystemI::createSoundInternal             : Create name='Content/Audio/Music/menu.ogg', mode=0x00000080
[LOG] SystemI::createSoundInternal             : Stream: name='(null)', format=2, channels=2, frequency=44100, lengthbytes=5574470, lengthpcm=14464800, pcmblocksize=0, loopstart=0, loopend=0, mode=0x00000000, channelmask=0x00000000, channelorder=0, peakvolume=0.000000.
[LOG] SystemI::createSoundInternal             : Create name='Content/Audio/Music/start.ogg', mode=0x00000080
[LOG] SystemI::createSoundInternal             : Stream: name='(null)', format=2, channels=2, frequency=44100, lengthbytes=279528, lengthpcm=505242, pcmblocksize=0, loopstart=0, loopend=0, mode=0x00000000, channelmask=0x00000000, channelorder=0, peakvolume=0.000000.
[LOG] SystemI::createSoundInternal             : Create name='Content/Audio/Music/tundra.ogg', mode=0x00000080
[LOG] SystemI::createSoundInternal             : Stream: name='(null)', format=2, channels=2, frequency=44100, lengthbytes=3846301, lengthpcm=11953694, pcmblocksize=0, loopstart=0, loopend=0, mode=0x00000000, channelmask=0x00000000, channelorder=0, peakvolume=0.000000.
[LOG] SystemI::createSoundInternal             : Create name='Content/Audio/Music/velvetguard_arena_finnish.ogg', mode=0x00000080
[LOG] SystemI::createSoundInternal             : Stream: name='(null)', format=2, channels=2, frequency=44100, lengthbytes=75670, lengthpcm=117600, pcmblocksize=0, loopstart=0, loopend=0, mode=0x00000000, channelmask=0x00000000, channelorder=0, peakvolume=0.000000.
[LOG] SystemI::createSoundInternal             : Create name='Content/Audio/SFX/angry.ogg', mode=0x00000001
[LOG] SystemI::createSoundInternal             : Sample 0/0: name='(null)', format=2, channels=1, frequency=48000, lengthbytes=17025, lengthpcm=27961, pcmblocksize=0, loopstart=0, loopend=0, mode=0x00000000, channelmask=0x00000000, channelorder=0, peakvolume=0.000000.
[LOG] SystemI::createSoundInternal             : Create name='Content/Audio/SFX/bounceBullet.ogg', mode=0x00000001
[LOG] SystemI::createSoundInternal             : Sample 0/0: name='(null)', format=2, channels=1, frequency=48000, lengthbytes=21074, lengthpcm=25322, pcmblocksize=0, loopstart=0, loopend=0, mode=0x00000000, channelmask=0x00000000, channelorder=0, peakvolume=0.000000.
[LOG] SystemI::createSoundInternal             : Create name='Content/Audio/SFX/buttonAction.ogg', mode=0x00000001
[LOG] SystemI::createSoundInternal             : Sample 0/0: name='(null)', format=2, channels=2, frequency=44100, lengthbytes=28647, lengthpcm=24436, pcmblocksize=0, loopstart=0, loopend=0, mode=0x00000000, channelmask=0x00000000, channelorder=0, peakvolume=0.000000.
[LOG] SystemI::createSoundInternal             : Create name='Content/Audio/SFX/button_back.ogg', mode=0x00000001
[LOG] SystemI::createSoundInternal             : Sample 0/0: name='(null)', format=2, channels=2, frequency=44100, lengthbytes=31340, lengthpcm=24436, pcmblocksize=0, loopstart=0, loopend=0, mode=0x00000000, channelmask=0x00000000, channelorder=0, peakvolume=0.000000.
[LOG] SystemI::createSoundInternal             : Create name='Content/Audio/SFX/button_click.ogg', mode=0x00000001
[LOG] SystemI::createSoundInternal             : Sample 0/0: name='(null)', format=2, channels=2, frequency=44100, lengthbytes=14127, lengthpcm=9483, pcmblocksize=0, loopstart=0, loopend=0, mode=0x00000000, channelmask=0x00000000, channelorder=0, peakvolume=0.000000.
[LOG] SystemI::createSoundInternal             : Create name='Content/Audio/SFX/dash.ogg', mode=0x00000001
[LOG] SystemI::createSoundInternal             : Sample 0/0: name='(null)', format=2, channels=1, frequency=44100, lengthbytes=17585, lengthpcm=16758, pcmblocksize=0, loopstart=0, loopend=0, mode=0x00000000, channelmask=0x00000000, channelorder=0, peakvolume=0.000000.
[LOG] SystemI::createSoundInternal             : Create name='Content/Audio/SFX/death.ogg', mode=0x00000001
[LOG] SystemI::createSoundInternal             : Sample 0/0: name='(null)', format=2, channels=1, frequency=44100, lengthbytes=26283, lengthpcm=27349, pcmblocksize=0, loopstart=0, loopend=0, mode=0x00000000, channelmask=0x00000000, channelorder=0, peakvolume=0.000000.
[LOG] SystemI::createSoundInternal             : Create name='Content/Audio/SFX/droppedBullet.ogg', mode=0x00000001
[LOG] SystemI::createSoundInternal             : Sample 0/0: name='(null)', format=2, channels=1, frequency=48000, lengthbytes=7845, lengthpcm=6236, pcmblocksize=0, loopstart=0, loopend=0, mode=0x00000000, channelmask=0x00000000, channelorder=0, peakvolume=0.000000.
[LOG] SystemI::createSoundInternal             : Create name='Content/Audio/SFX/explosion.ogg', mode=0x00000001
[LOG] SystemI::createSoundInternal             : Sample 0/0: name='(null)', format=2, channels=1, frequency=44100, lengthbytes=34266, lengthpcm=50531, pcmblocksize=0, loopstart=0, loopend=0, mode=0x00000000, channelmask=0x00000000, channelorder=0, peakvolume=0.000000.
[LOG] SystemI::createSoundInternal             : Create name='Content/Audio/SFX/explosionTick.ogg', mode=0x00000001
[LOG] SystemI::createSoundInternal             : Sample 0/0: name='(null)', format=2, channels=1, frequency=44100, lengthbytes=6717, lengthpcm=4469, pcmblocksize=0, loopstart=0, loopend=0, mode=0x00000000, channelmask=0x00000000, channelorder=0, peakvolume=0.000000.
[LOG] SystemI::createSoundInternal             : Create name='Content/Audio/SFX/fire_bullet.ogg', mode=0x00000001
[LOG] SystemI::createSoundInternal             : Sample 0/0: name='(null)', format=2, channels=1, frequency=44100, lengthbytes=17909, lengthpcm=22050, pcmblocksize=0, loopstart=0, loopend=0, mode=0x00000000, channelmask=0x00000000, channelorder=0, peakvolume=0.000000.
[LOG] SystemI::createSoundInternal             : Create name='Content/Audio/SFX/hit.ogg', mode=0x00000001
[LOG] SystemI::createSoundInternal             : Sample 0/0: name='(null)', format=2, channels=1, frequency=48000, lengthbytes=16293, lengthpcm=25322, pcmblocksize=0, loopstart=0, loopend=0, mode=0x00000000, channelmask=0x00000000, channelorder=0, peakvolume=0.000000.
[LOG] SystemI::createSoundInternal             : Create name='Content/Audio/SFX/jump.ogg', mode=0x00000001
[LOG] SystemI::createSoundInternal             : Sample 0/0: name='(null)', format=2, channels=1, frequency=48000, lengthbytes=6684, lengthpcm=3040, pcmblocksize=0, loopstart=0, loopend=0, mode=0x00000000, channelmask=0x00000000, channelorder=0, peakvolume=0.000000.
[LOG] SystemI::createSoundInternal             : Create name='Content/Audio/SFX/landing.ogg', mode=0x00000001
[LOG] SystemI::createSoundInternal             : Sample 0/0: name='(null)', format=2, channels=1, frequency=48000, lengthbytes=26993, lengthpcm=39093, pcmblocksize=0, loopstart=0, loopend=0, mode=0x00000000, channelmask=0x00000000, channelorder=0, peakvolume=0.000000.
[LOG] SystemI::createSoundInternal             : Create name='Content/Audio/SFX/pause.ogg', mode=0x00000001
[LOG] SystemI::createSoundInternal             : Sample 0/0: name='(null)', format=2, channels=2, frequency=44100, lengthbytes=35791, lengthpcm=27777, pcmblocksize=0, loopstart=0, loopend=0, mode=0x00000000, channelmask=0x00000000, channelorder=0, peakvolume=0.000000.
[LOG] SystemI::createSoundInternal             : Create name='Content/Audio/SFX/phaser_phase.ogg', mode=0x00000001
[LOG] SystemI::createSoundInternal             : Sample 0/0: name='(null)', format=2, channels=1, frequency=44100, lengthbytes=79424, lengthpcm=176400, pcmblocksize=0, loopstart=0, loopend=0, mode=0x00000000, channelmask=0x00000000, channelorder=0, peakvolume=0.000000.
[LOG] SystemI::createSoundInternal             : Create name='Content/Audio/SFX/pierceSound.ogg', mode=0x00000001
[LOG] SystemI::createSoundInternal             : Sample 0/0: name='(null)', format=2, channels=1, frequency=44100, lengthbytes=15764, lengthpcm=18432, pcmblocksize=0, loopstart=0, loopend=0, mode=0x00000000, channelmask=0x00000000, channelorder=0, peakvolume=0.000000.
[LOG] SystemI::createSoundInternal             : Create name='Content/Audio/SFX/powerup.ogg', mode=0x00000001
[LOG] SystemI::createSoundInternal             : Sample 0/0: name='(null)', format=2, channels=1, frequency=96000, lengthbytes=44029, lengthpcm=74943, pcmblocksize=0, loopstart=0, loopend=0, mode=0x00000000, channelmask=0x00000000, channelorder=0, peakvolume=0.000000.
[LOG] SystemI::createSoundInternal             : Create name='Content/Audio/SFX/rocks_falling0.ogg', mode=0x00000001
[LOG] SystemI::createSoundInternal             : Sample 0/0: name='(null)', format=2, channels=1, frequency=44100, lengthbytes=139501, lengthpcm=185306, pcmblocksize=0, loopstart=0, loopend=0, mode=0x00000000, channelmask=0x00000000, channelorder=0, peakvolume=0.000000.
[LOG] SystemI::createSoundInternal             : Create name='Content/Audio/SFX/rocks_falling1.ogg', mode=0x00000001
[LOG] SystemI::createSoundInternal             : Sample 0/0: name='(null)', format=2, channels=1, frequency=44100, lengthbytes=17270, lengthpcm=18103, pcmblocksize=0, loopstart=0, loopend=0, mode=0x00000000, channelmask=0x00000000, channelorder=0, peakvolume=0.000000.
[LOG] SystemI::createSoundInternal             : Create name='Content/Audio/SFX/rocks_falling2.ogg', mode=0x00000001
[LOG] SystemI::createSoundInternal             : Sample 0/0: name='(null)', format=2, channels=1, frequency=44100, lengthbytes=119207, lengthpcm=153601, pcmblocksize=0, loopstart=0, loopend=0, mode=0x00000000, channelmask=0x00000000, channelorder=0, peakvolume=0.000000.
[LOG] SystemI::createSoundInternal             : Create name='Content/Audio/SFX/round_alarm.ogg', mode=0x00000001
[LOG] SystemI::createSoundInternal             : Sample 0/0: name='(null)', format=2, channels=1, frequency=44100, lengthbytes=24285, lengthpcm=33375, pcmblocksize=0, loopstart=0, loopend=0, mode=0x00000000, channelmask=0x00000000, channelorder=0, peakvolume=0.000000.
[LOG] SystemI::createSoundInternal             : Create name='Content/Audio/SFX/scream.ogg', mode=0x00000001
[LOG] SystemI::createSoundInternal             : Sample 0/0: name='(null)', format=2, channels=1, frequency=48000, lengthbytes=20978, lengthpcm=26690, pcmblocksize=0, loopstart=0, loopend=0, mode=0x00000000, channelmask=0x00000000, channelorder=0, peakvolume=0.000000.
[LOG] SystemI::createSoundInternal             : Create name='Content/Audio/SFX/shield.ogg', mode=0x00000001
[LOG] SystemI::createSoundInternal             : Sample 0/0: name='(null)', format=2, channels=1, frequency=48000, lengthbytes=18340, lengthpcm=24000, pcmblocksize=0, loopstart=0, loopend=0, mode=0x00000000, channelmask=0x00000000, channelorder=0, peakvolume=0.000000.
[LOG] SystemI::createSoundInternal             : Create name='Content/Audio/SFX/shield_reflect.ogg', mode=0x00000001
[LOG] SystemI::createSoundInternal             : Sample 0/0: name='(null)', format=2, channels=1, frequency=48000, lengthbytes=13793, lengthpcm=15190, pcmblocksize=0, loopstart=0, loopend=0, mode=0x00000000, channelmask=0x00000000, channelorder=0, peakvolume=0.000000.
[LOG] SystemI::createSoundInternal             : Create name='Content/Audio/SFX/snow_storm.ogg', mode=0x00000001
[LOG] SystemI::createSoundInternal             : Sample 0/0: name='(null)', format=2, channels=2, frequency=48000, lengthbytes=11070275, lengthpcm=10019430, pcmblocksize=0, loopstart=0, loopend=0, mode=0x00000000, channelmask=0x00000000, channelorder=0, peakvolume=0.000000.
[LOG] SystemI::createSoundInternal             : Create name='Content/Audio/SFX/water_drop0.ogg', mode=0x00000001
[LOG] SystemI::createSoundInternal             : Sample 0/0: name='(null)', format=2, channels=1, frequency=44100, lengthbytes=16822, lengthpcm=20681, pcmblocksize=0, loopstart=0, loopend=0, mode=0x00000000, channelmask=0x00000000, channelorder=0, peakvolume=0.000000.
[LOG] Thread::callback                         : FMOD stream thread finished.
[WRN] OutputALSA::updateMixer                  : Under-run detected in ALSA output buffer! snd_pcm_writei returned -5 = Input/output error.
[WRN] OutputALSA::updateMixer                  : Under-run detected in ALSA output buffer! snd_pcm_writei returned -77 = File descriptor in bad state.
The audio works for other applications with no problems, its using 44100 sample rate, 2 sample channels, s16le sample format.
Sorry for the delayed response, and thanks for the extended log.
Please try running aplay -L in a terminal, and check whether your usual audio output device is present in the output. If it isn’t, you may need to either add a namehint to the device’s .asoundrc configuration file, or set defaults.namehint.showall to on in your ALSA configuration file /usr/share/alsa/alsa.conf in order for FMOD to detect it properly.
If this isn’t the case, or doesn’t resolve the issue, could I get you to run the following commands to update PulseAudio and ALSA, and see whether that makes any difference when you run your FMOD system?
  • sudo apt-get install libpulse-dev
  • sudo apt-get install libasound2-dev
Also, are you aware of any other modifications to your OS’s normal audio setup? For example:
  • Have any audio config files been manually modified?
  • Are you using any other audio libraries or ALSA plugins? i.e. jack, pipewire, softvol, dmix
