Basic Audio Implementation Questions
Hi Folks,
quick basic question for everyone. How do I switch an already created event from 3D to 2D or vice versa ?
Thanks,
Kristi
Just simply click on the master channel in the event window, look at the bottom bar. From there right click and delete The 3D Panner and you’ll be set.
To verify that it worked right, you should only see two channels (L-R) going out and no longer see all 6 from a 3D sound.
Oh yeah… to change it back, just right click in that same bottom window and add 3D Panner.
Thanks JB that did the trick!
