Greetings, Im currently evaluating FMOD Studio by doing many things that usually would break software, so far Wwise has been pretty good, when i import the same clean .wav files 1.35TB into FMOD previously and try to reload the project, next reboot of the PC. the executable loads 99%, freezes, and then loads 100% then the GUI progress bar disappears and doesn’t load anything and the exe sits there with 0% CPU, 1.2GB of RAM and 0% disk activity.
tried to reboot and re-open FMOD but fails now.
Apologies for the delayed response.
I’m not sure that importing terabytes worth of audio at once falls under the expected scope of our audio import functionality, but I have flagged some tests internally around importing large amounts of audio to see whether there’s anything we can improve on there.
I managed to work around this by clearing my FMOD cache in my appdata, and some other locations I can’t recall, currently on 2.03 of FMOD and it hands for a bit before it decides to work again
Glad to hear you managed to get it working again - I’ve noted your solution internally.
