I have a nested parameter sheet with a local parameter (holding its value during playback) automated by a global parameter :
In the parent event, if I change the global parameter value outside the trigger zone of the nested event, it works fine: the nested event continues to play until the end of its content, and then changes the parameter only at the next retrigger (while stacking with the tail of the previous instance). However, if I change the parameter value inside the nested event trigger zone, it stops playing when untriggered.
