[BUG] Settings.Instance doesn't check its current thread before calling Resources.Load
I’ve had a few editor freezes when live-recompiling code, and when checking the source, it appeared that every freeze was caused by a fmod external call.
The last one was caused by a unity exception thrown on DEBUG_CALLBACK
The stack was:
Resources.Load
Initialize
Settings.Instance
DebugLogWarning
DEBUG_CALLBACK
(had to do it from memory since I didn’t copy the code)
Resources.Load cannot be called from the fmod callback thread. This could be fixed by just modifying Instance.Initialize to something like:
        internal static void Initialize()
            if (instance == null)
                isInitializing = true;
                instance = null;
                // TODO: create issue about this in fmod forum
                try
                    instance = Resources.Load(SettingsAssetName) as Settings;
                catch (Exception e)
                    // This call will not recursively call Initialize() again since isInitializing is set to true.
                    RuntimeUtils.DebugLog($"[FMOD] Tried to init Settings instance from wrong thread: {e}");
                    isInitializing = false;
                    return;
                    RuntimeUtils.DebugLog("[FMOD] Cannot find integration settings, creating default settings");
                    instance = CreateInstance<Settings>();
                    instance.name = "FMOD Studio Integration Settings";
                    instance.CurrentVersion = FMOD.VERSION.number;
                    instance.LastEventReferenceScanVersion = FMOD.VERSION.number;
#if UNITY_EDITOR
                    if (editorSettings != null)
                        editorSettings.CreateSettingsAsset(SettingsAssetName);
                    else
                        // editorSettings is populated via the static constructor of FMODUnity.EditorSettings when in the Unity editor.
                        RuntimeUtils.DebugLogError("[FMOD] Attempted to instantiate Settings before EditorSettings was populated. " +
                            "Ensure that Settings.Instance is not being called from an InitializeOnLoad method or class.");
#endif
Thank you for reporting the issue and information.
I have added this as a task that we will look into for an upcoming release.
