Hi! I have a multi instrument block set up for a left hand piano part, which has two audio files inside of it. I have the first audio file (which is a straight rhythm) set to play 80% of the time and the second (which is a little bit different with some syncopation) set to play 20% of the time. Is it possible to automate the play percentages?
Ideally, it would be great if it could start at 80/20 like this, and then each time it loops, it gradually changes to be at 20/80.
Is there any clean way to do this, other than just manually doing it by hand in a more linear way?
