Can't make a PS4 build in Unity when using FMod
#1
We’re having trouble deploying to PS4. It seems like we can’t make a build in Unity to PS4 when FMod is in the project. It builds fine when all FMod related components from the project are deleted. We’re using FMod Studio + Unity integration version 1.08.12. Unity version 5.4. Any ideas?
#2
Could you please provide some details about what is going wrong? Are you receiving error messages? or is there some log output you could share?
#3
When trying to do a build to the PlayStation 4: The game won’t finish booting up and the PC hosted build says "Unable to resolve pinvoke method “FMOD.Memory:FMOD5_Memory_GetStats(int&, int&, bool)” Seems like someone on the Playstation forums had the same problem, I asked our programmer Josh Blidook, he said the solution to delete the .dlls didn’t work in our case.
#4
We have identified a problem with the Unity integration.
You can resolve this by manually deleting the fmod.dll and fmodl.dll files from both the Plugins/x86 & Plugins/x86_64 folders.
This fix will be out next update.
#5
This didn’t work for us unfortunately
#6
It looks like you are then missing the ps4 specific dll’s. Please refer to http://www.fmod.org/questions/question/how-do-i-get-access-to-console-versions/
