Hello there.
Fmod Version : 1.7.5
Ue4 : 10.2
I’m trying to change the pitch of many different events at the same time.
It seems I can’t do it with Snapshot as it only allows for mixing changes (I don’t want to use the pitch shifter).
So I added a parameter to theses events, with the same name. Still I can’t cast this only common parameter in Unreal to change things on those different events.
I tried to make an event parent that reference all the others and has the same parameter. Didn’t worked (because in Unreal the other events are not trigged from the parent but from their base events, in other BP than the one I change the parameter from).
Is there a way to tweak some kind of global parameters? Like the last solution I tried would be awesome (if it worked). Or a function that allows to reference a parameter and use it even if it belongs to many different events!
Like a Parameter Matrix, where you could tweak all parameters values, and patch them.
