Reuse Global Parameter Across Multiple Events
I have multiple events that I want to vary (e.g play different sound clips) based on the same parameter. Is there any way to have them all use the same global parameter, or do I need to create separate parameters for each?
That’s exactly the purpose of setting the parameter as “global”.
Whoops, it turns out I was interacting with the UI wrong. I was looking through the Create dropdown menu and didn’t try just adding a parameter sheet…
Good to hear it’s working! Thanks for sharing your solution here.
