Is it possible to change the Mixer’s Master Bus output from 5.1 to Stereo in FMOD Studio 1.08.12?
Hi Steven
You can do this by changing the project speaker mode for your platform to Stereo.
- From the Edit menu choose Preferences
- On the Build tab select the platform you are working on
- Set the speaker mode to Stereo
- Close the Preferences window
The master bus will now be set to stereo output.
