We are using FMOD 2.03.09. Somehow, the reverb doesn’t work on PS5, while the other console (XBOX Series, PC) is working. FMOD sound is working on PS5, but DSP is not.
Do you have any clue regarding this?
Do we need to include plugin libresonanceaudio?
If it is working on other platforms, then I’m assuming your setup should be right. libresonanceaudio is only required if you are using the Resonance DSP effects in your Studio project.
Are you seeing any warnings or errors in the output log from the PS5?
Changing the Logging Level in the FMOD UE Settings to LEVEL LOG will provide a lot more information for debugging, as well as checking the Enable API Error Logging option.
