What is the correct way to call getFadePoints?
unsigned int numpoints;
unsigned long long *point_dspclock;
float *point_volume;
result = channel->getFadePoints(&numpoints, point_dspclock, point_volume);
I’m doing this, but get a crash. I’d ideally like to check the dspclocks and volumes.
Thanks in advance!
I eventually worked this out. You have to call getFadePoints twice with different arguments:
1st time will nullptr args for the volumes/fade points:
result = channel->getFadePoints(&numpoints, nullptr, nullptr);
then you pass an integer corresponding to the point number to getFadePoints
for (int i = 0; i < numpoints; i++) {
unsigned int num_point = static_cast<unsigned int>(i);
unsigned long long point_dspclock;
float point_volume;
result = channel->getFadePoints(&num_point, &point_dspclock, &point_volume);
Apologies for not getting back to you, but thank you for sharing the solution!
