Hi FMOD-fiends!
So I’ve just discovered you can drive Parameters with modulation, which solves a TON of design problems I had envisioned.
However, I’ve noticed when driving parameters with LFOs at specific ranges, I’m getting a ton of crashes. I’d love to submit some crash reports or such to see if this is a problem for anyone else.
Any info that can be supplied would be great!
Update: :Looks like if you set your Seek speed to infinite the crash happens, but if the speed is slower, it won’t crash.
