Hi!
If you want to smoothly transition between different volume automation values, it’s not directly possible. You could put a “+1” here or here. There also are some (curbersome) workarounds on these links.
Related topics
| Topic | Replies | Views | Activity | |
| Crossfade nested events and parameter | 3 | 2012 | October 1, 2017 | |
| Crossfading between audio tracks when using a discrete parameter | 5 | 1790 | August 28, 2024 | |
| How to ignore ADHSR on loop? | 2 | 1154 | February 21, 2020 | |
| Going from A to D without going through B and C? | 2 | 75 | July 11, 2025 | |
| Transitions for Labelled Parameters | 36 | 4485 | January 16, 2025 |
