I have a sound that is sorted into 4 categories. Small Medium Large. Also variable A B C D.
So in total I have 12 sounds. Small A, Small B, Small C Small D. Medium A, Medium B etc.
I would love to have all of these sounds within a single FMOD event.
I want the sounds to play looped and the go through each variation (A S, A M, A L, B S, BM etc), depending on 2 different parameters.
Let’s call the parameters “Letter” and “Size”.
In the beginning I want for instance to play A S. Then the parameters change to C L. I want then to fade A S out and fade in C L. This should be done via a crossfade, not a “when A S is faded out, then play C L”. The sound should then play until for instance B M is called.
Then I would crossfade to B M, from C L.
Currently I can’t find a way to do this. I can only find 2 ways to do this: Either fading out one sound, and once that has faded out, I can fade in the next sound (this is done via ADSHR).
Or if I want to go straight from A to D, I will have to cycle through C and D first (done via seek speed).
Any idea on how I could go straight from A to D without going through B and C first, and still maintaining crossfades?
