Don’t worry, the seek modulator is entirely compatible with labelled parameters!
However, you probably wouldn’t want to apply it to a labelled parameter in the use-case discussed in this thread’s earlier posts. Instead, you’d apply it directly to the value of the property being automated, so that sudden changes in the labelled parameter’s value result in gradual changes to the automated property’s value.
