I’m using a custom DSP to draw the realtime wave form of a playing mp3 in a UWP application.
The read call back is now defined as:
private unsafe RESULT dspReadCBDo(ref DSP_STATE dsp_state, IntPtr inbuffer, IntPtr outbuffer,
uint length, int inchannels, ref int outchannels)
float* bufferIN = (float*)inbuffer;
float* bufferOUT = (float*)outbuffer;
for (int i = 0; i < length; i++)
for (int c = 0; c < outchannels; c++)
var val = bufferIN[i * inchannels + c];
bufferOUT[i * outchannels + c] = val;
bufferWave[c][i] = val;
return FMOD.RESULT.OK;
Buffer wave is a float[][] that I use later in code to draw the wave.
Is it the best way to do it or may I have better performance? I mean, if I just set outbuffer = inbuffer, data is not passing to the outbuffer and no sound is played. Is processing every single bin necessary to have the DSP working? Is possible to just read signal and store it in the bufferWave array without the need to assigning every float to the outbuffer?
