Documentation refers to fMod Studio 2.1 instead of 2.01
There seems to be some discrepency in the documentation over fMod Studio 2.01, as it is often referred to as 2.1 instead. As far as I can tell, 2.1 does not exist yet, so it is extremely confusing. For instance here it is refered to as 2.1, but in the sidebar it is 2.01.
https://fmod.com/resources/documentation-studio?version=2.1&page=welcome-to-fmod-studio-new-in-201.html
Thank you for reporting this error in our documentation. I’ve added it to our feature/improvement tracker, so it will be corrected in an upcoming update to our documentation.
I should clarify that there will never actually be a “version 2.1” of FMOD Studio. FMOD Studio’s version numbers are a series of separate numbers separated by periods, rather than decimals, so version 2.09 will be followed by version 2.10, which we’ll pronounce “two point ten.” (This is a relatively common practice in software version numbering.)
In any case, you’re definitely right that using “2.1” instead of “2.01” in our documentation is confusing. We’ll be sure to fix it.
FYI https://www.fmod.com/studio also lists the new version as 2.1 :slight_smile:
Thanks for the bug report. I’ve added it to our tracker.
