Double Click on Tempo Marker not working?
I’m fairly new to FMOD. I’ve added a Tempo Marker and I want to change it from the default 120 bpm to 100 bpm. My understanding is that I just need to double-click on the Tempo Marker to edit it but when I double-click nothing happens. Any ideas?
Thanks
Hi Chris,
That certainly is odd behaviour. I have tested in 1.10.04 on Windows and Mac and both seem to work as expected.
Could you please verify if this happens in a new project as well, or is it just the project you’re working in? Could you open the logs (Window > Console > Logging) and see if there are any errors listed here?
Thanks,
Richard
Hi Richard,
It’s on a new project. I’ve just opened a new project, created a tempo marker and double clicked the marker and nothing? I uninstalled FMOD and tried re-installing (1.10.05) but still not working. I also downloaded FMOD on to my MacBook and it all seemed to work. This is what I get under Logging on my windows machine:
11:12:12 [Initialize Sound System 0x00000000049c1e90]: Time started
11:12:13 [Initialize Sound System 0x00000000049c1e90]: Time taken is 314.38ms
11:12:14 Web channel server started on: wss://127.0.0.1:12345
11:12:14 [Initialize Sound System 0x000000000556a280]: Time started
11:12:15 fmod_systemi.cpp(2759), SystemI::init(): Output requires a sample rate of 44100Hz, resampling will occur.
11:12:15 [Initialize Sound System 0x000000000556a280]: Time taken is 979.33ms
11:12:15 [Uninitialize Sound System 0x000000000556a280]: Time started
11:12:15 [Uninitialize Sound System 0x000000000556a280]: Time taken is 47.41ms
11:12:15 [Initialize Sound System 0x000000000556a280]: Time started
11:12:16 fmod_systemi.cpp(2759), SystemI::init(): Output requires a sample rate of 44100Hz, resampling will occur.
11:12:16 [Initialize Sound System 0x000000000556a280]: Time taken is 562.11ms
11:12:16 ScriptServer started on 0.0.0.0 (3663)
11:12:17 fmod_objectlookup.h(119), ObjectLookup::get(): Lookup failed for Routable: {126cb4a9-051c-474e-9e83-00290986e088}
11:12:22 fmod_objectlookup.h(119), ObjectLookup::get(): Lookup failed for Routable: {b5705160-ff33-4e78-a537-a92e2d492d75}
11:12:22 fmod_objectlookup.h(119), ObjectLookup::get(): Lookup failed for Routable: {d611c1a4-09ef-4cd0-9bcc-edeb10d8e694}
Thanks
Chris
Hi Chris,
This looks to just be the initialization of the FMOD system. Do you see anything listed as being an error? It will also be coloured red.
Thanks,
Richard
Hi Chris,
Are you still having issues with editing tempo markers?
Thanks,
Richard
Hi Richard,
Sorry I didn’t get notified that you had replied. Yes, I am still having the problems. I’ve been working on my MacBook and it has been working fine but I would prefer to use my PC. I’ve downloaded the latest version and just reinstalled but still unable to edit the tempo when double clicking? This is what I got under the Loggin this time. Nothing in red just a couple of lines in yellow (see below).
20:08:30 fmod_systemi.cpp(2822), SystemI::init(): Output requires a sample rate of 44100Hz, resampling will occur.
20:08:31 fmod_systemi.cpp(2822), SystemI::init(): Output requires a sample rate of 44100Hz, resampling will occur.
Full Logging:
20:08:28 [Initialize Sound System 0x000000000596efa0]: Time started
20:08:28 [Initialize Sound System 0x000000000596efa0]: Time taken is 79.99ms
20:08:30 Web channel server started on: wss://127.0.0.1:12345
20:08:30 [Initialize Sound System 0x0000000005981120]: Time started
20:08:30 [Initialize Sound System 0x0000000005981120]: Time taken is 698.92ms
20:08:30 [Uninitialize Sound System 0x0000000005981120]: Time started
20:08:30 [Uninitialize Sound System 0x0000000005981120]: Time taken is 40.01ms
20:08:31 [Initialize Sound System 0x0000000005981120]: Time taken is 577.87ms
20:08:31 ScriptServer started on 0.0.0.0 (3663)
Any ideas?
Thanks
Chris
I have a similar problem. I have to delete and create new marker every time when I want to edit the marker. Fmod Studio 1.10.05, build #94661, 64bit, macOS.
