Tempo Marker is off by 1
Hi, as the title says. I was on Studio 2.03.06 and updated to 2.03.11 and have the same problem:
I have this piece of music that is at 120 BPM and is 40 measures long (1m20s). If I set a Tempo Marker at 120 at the beginning of the timeline, the bars don’t line up correctly, like the music is 41 measures and a bit long. If I set the tempo to 119 BPM, it lines up perfectly.
At first I thought it might be a 44.1 VS 48 Khz issue with my asset but it’s not. It just seems that I need to write 1 less BPM than I actually need.
Unfortunately, I haven’t been able to reproduce the issue on my end with 2.03.11 using a 120bpm click track - the click track lines up as expected with the tempo marker lines at both 44.1kHz and 48kHz.
If possible, could I get you to upload the problem audio file to the Uploads tab of your FMOD user profile for me to take a look at? It will only be accessible to yourself and FMOD staff. If that’s not possible, a video of you demonstrating the issue instead would be great.
This seems to be a very dumb mistake on my part with my export. Apologies. :frowning:
