Effect automation not working as preset if parameter is global
2.02.14 version
Steps to reproduce:
  • create event for testing;
  • insert some assets to that event for auditioning and testing;
  • create some global parameter and add it to that event;
  • insert Gain effect and create automation in it for this global parameter;
  • try to change global parameter and listen how Gain is changed - all is ok;
  • convert that Gain effect to Preset;
  • try to change global parameter and listen how Gain is changed - it’s NOT changing;
  • detach that Gain effect back from Preset;
  • try to change global parameter and listen how Gain is changed - all is ok again
Problem persist not only with Gain effect (I tried Lowpass Simple also)
This bug was fixed as of 2.02.17 - please update to that version and let me know whether the issue persists.
We updated to 2.02.22 and the problem is gone, thank you!
(Maybe I missed info in new version’s changelog about that)
