Effects CPU usage when return bus has no signal passing through it?
@joseph Thanks for clarifying.
And since there is NO current way to automate plugin bypass state ( Effect bypass automation function plans? - #15 by joseph ), there isn’t a straightforward workaround for momentarily disabling resources when return effects aren’t in use (some kind of “idle mode”), right?
