I’m working with the FMOD studio API on a raspberry pi 3 B: linux api version 1.10.05
When I use the built-in sound output everything works fine. When I set my USB soundcard (ESI gigaport HD+) as the systems default sound output I get FMOD error 51 – Error initializing output device. The soundcard works fine outside of the FMOD API.
I generated a log file, which shows the specific error: [ERR] OutputALSA::init                         : snd_pcm_hw_params_set_rate returned -22 = Invalid argument.
I realise that this could be a really device/driver specific problem but I have no clue what this error means, could anyone point me in the right direction?
LOG:
[LOG] System::create                           : Header version = 1.10.05. Current version = 1.10.05.
[LOG] Manager::init                            : maxchannels = 256 studioflags = 00000000 flags 00000000 extradriverdata (nil).
[LOG] SystemI::init                            : Initialize version=11005 (94661), maxchannels=256, flags=0x00020000
[LOG] FMOD_OS_Init                             : Detected Neon instruction support, will use Neon optimized mixing and resampling.
[LOG] SystemI::setOutputInternal               : Setting output to ‘FMOD ALSA Output’
[LOG] OutputALSA::registerLib                  : Loaded ALSA version 1.1.3.
[LOG] OutputALSA::enumerate                    : Found device NAME:null IOID:(null).
[LOG] OutputALSA::enumerate                    : Found device NAME:default IOID:(null).
[LOG] OutputALSA::enumerate                    : Found device NAME:sysdefault:CARD=ALSA IOID:Output.
[LOG] OutputALSA::enumerate                    : Found device NAME:dmix:CARD=ALSA,DEV=0 IOID:Output.
[LOG] OutputALSA::enumerate                    : Found device NAME:dmix:CARD=ALSA,DEV=1 IOID:Output.
[LOG] OutputALSA::enumerate                    : Found device NAME:dsnoop:CARD=ALSA,DEV=0 IOID:Output.
[LOG] OutputALSA::enumerate                    : Found device NAME:dsnoop:CARD=ALSA,DEV=1 IOID:Output.
[LOG] OutputALSA::enumerate                    : Found device NAME:hw:CARD=ALSA,DEV=0 IOID:Output.
[LOG] OutputALSA::enumerate                    : Found device NAME:hw:CARD=ALSA,DEV=1 IOID:Output.
[LOG] OutputALSA::enumerate                    : Found device NAME:plughw:CARD=ALSA,DEV=0 IOID:Output.
[LOG] OutputALSA::enumerate                    : Found device NAME:plughw:CARD=ALSA,DEV=1 IOID:Output.
[LOG] OutputALSA::enumerate                    : Found device NAME:sysdefault:CARD=HD IOID:Output.
[LOG] OutputALSA::enumerate                    : Found device NAME:front:CARD=HD,DEV=0 IOID:Output.
[LOG] OutputALSA::enumerate                    : Found device NAME:surround21:CARD=HD,DEV=0 IOID:Output.
[LOG] OutputALSA::enumerate                    : Found device NAME:surround40:CARD=HD,DEV=0 IOID:Output.
[LOG] OutputALSA::enumerate                    : Found device NAME:surround41:CARD=HD,DEV=0 IOID:Output.
[LOG] OutputALSA::enumerate                    : Found device NAME:surround50:CARD=HD,DEV=0 IOID:Output.
[LOG] OutputALSA::enumerate                    : Found device NAME:surround51:CARD=HD,DEV=0 IOID:Output.
[LOG] OutputALSA::enumerate                    : Found device NAME:surround71:CARD=HD,DEV=0 IOID:Output.
[LOG] OutputALSA::enumerate                    : Found device NAME:iec958:CARD=HD,DEV=0 IOID:Output.
[LOG] OutputALSA::enumerate                    : Found device NAME:dmix:CARD=HD,DEV=0 IOID:Output.
[LOG] OutputALSA::enumerate                    : Found device NAME:dsnoop:CARD=HD,DEV=0 IOID:Output.
[LOG] OutputALSA::enumerate                    : Found device NAME:hw:CARD=HD,DEV=0 IOID:Output.
[LOG] OutputALSA::enumerate                    : Found device NAME:plughw:CARD=HD,DEV=0 IOID:Output.
[LOG] SystemI::close                           : Closed.
[LOG] LiveUpdate::release                      :
[LOG] LiveUpdate::reset                        : Reset connection (reason Disconnected)
Kind regards,
Simon
