Error Saving Session "Error writing to.....Make sure you have write permission to the file."
I’m continuously getting this intermittent error when saving.
Error writing to C:/Users/Playtest PC/AppData/Local/FMOD
Studio/UnsavedProjects/Project-WtXUC8/DesignerToStudio/{d1972e0f-ab7e-420e-a582-d2ddef9b2c4c}/.unsaved/Metadata/Workspace.xml.
I’m unable to save my session.
From the error message, it looks like the error occurred after opening a Designer project is that correct? When trying to save, did Studio present a prompt asking for a new location to save the project to? Would you be able to provide the Studio version you are using?
“error occurred after opening a Designer project is that correct?”
That is correct
“did Studio present a prompt asking for a new location to save the project to?”
yes
1.09.04
still getting this error. Are there any insights you can offer?
I have yet to reproduce this locally. The next best thing to do is to send us the logs via “Help->contact support@fmod.com” after you encountered the issue.
Having the same problem after accidentally quitting FMOD 2.01.01 (ctrl+w, because that’s the default command for duplicate in Unreal Engine, so habit), and opening it up again.
Can you send us logs as per Thuan’s previous reply please?
