Event not in DataTable '/Game/FMOD/PrivateIntegrationData/AssetLookup.AssetLookup'
I use ue4 patch to update AssetLookup Table,but is not work。It seem use the older one。I make sure the newer AssetLookup is patch in the patch pak.Is any config I wrong?
What version of FMOD and UE are you using?
Could you elaborate a bit more and if there are any error logs you could share?
