Export / Build Error with Unreal Engine 5.7.4 and FMOD Plugin
Hey yall! Our team and I are running into a bit of an issue We’re trying to export a build of a game that uses unreal 5.7.4 with the fmod plugin but it doesn’t seem to work
The game and audio runs fine in editor but when trying to export a build we get the following error message:
Here is a screenshot showing our Plugin version 2.03.14
Any help would be greatly appreciated. Thanks in advance!
Thanks for sharing the version number and screenshots.
This looks like a known issue with Blueprint-only projects. Is your project a Blueprint-only project?
If so, could you please try following our Unreal Integration | Troubleshooting - Blueprint only projects to add a C++ class to the project and see if that resolves the issue?
