Feature request "Effect Chain" Dry/Wet Knob
Hi all,
Can you add a Dry/Wet knob (with automation possible) on “Effect Chain”
It can be an easy way to apply an effect like a radio without use a return track/mixer.
What do you think about?
Just to clarify, are you interested in wet/dry control for individual effect in an effect chain or wet/dry control for an entire chain?
Thanks for the response.
To be clear, wet/dry control for an entire chain,
In another case, it’s possible to do a dry/wet with mix control in the chorus for the example but not with spatalizer,
example: it would be possible to blend between 2D/3D event with a wet/dry control on a spatalizer.
But if we have wet/dry control on “Effect Chain” we can control all the other effects undirectly from “Effect Chain” wet/dry control.
You could create a snapshot that modifies all the knobs you want in the mixer, or have a global parameter that modifies multiple effects at the same time!
I only propose a wet/dry control new feature in the “Effect Chain”.
Thanks for the feedback. We will add that to the list of potential features to investigate for future releases.
Thank you !
