Fmod audio still playing after exit play-mode in Unity Editor
(Yudi Xiao) #1
I am currently using Unity 2017.1.1f1 and FMOD 1.10.00 under Windows 10. I have a script that will start an FMOD audio instance at Start(), using the timeline callback example code and also have the stop and release code in OnDestroy(). I notice sometimes after I quit play mode in Unity Editor, FMOD audio instance will not stop playing.
Any suggestion what should I look into?
Here are what is in the FMOD log when this issue happen :
https://drive.google.com/open?id=0B0RKyy22nEsLaGxjcEhvYmlfU3M
(Cameron Baron) #2
Are you getting any errors or warnings in Unity?
(Yudi Xiao) #3
Nothing related to FMOD in Unity console, should I check FMOD log for this?
(Cameron Baron) #4
It might be worth checking. Otherwise if you have a small project that reproduces the issue you would be able to share with us, we can take a look.
(Yudi Xiao) #5
Updated a picture showing what is in FMOD’s log viewer (could not copy form there, this is the best I could do). Will try to reproduce this in an empty project.
(Cameron Baron) #6
Thanks, unfortunately the file is behind a secure login.
(Yudi Xiao) #7
Sorry about that, looks like my email marking reply notification email as harassment. And I just updated the image link. Might if you can take a look and tell me is there anything I should be looking into?
(Cameron Baron) #8
I can’t see anything that stands out. Are you able to reliably reproduce the issue?
Is there any other information you can provide that may help me recreate it here?
