FMOD Documentation links redirect to welcome page
I see previous topics published about this, but they’ve been marked as solved. The issue seems to be happening again, links such as:
https://www.fmod.com/docs/2.02/unity/api-runtimemanager.html
https://fmod.com/docs/2.02/api/studio-api-eventdescription.html
redirect to welcome.html
There might be more broken links, these are the ones i’ve found so far.
Hi i’ve tried those links on 3 different browsers and they all go to the correct page. Have you tried deleting your cache/incognito mode / a different browser/machine?
Looks like it’s working now! I had tried 2 different browsers this morning with the same behavior but it doesn’t seem to be happening anymore.
This is still happening, I cannot view the settings page at all (or platform specifics, some work others don’t). 2.03
https://fmod.com/docs/2.03/unity/settings.html
https://fmod.com/docs/2.03/unity/welcome.html
Some other pages too. I’m pretty sure I’ve had similar problems in the past and just stopped using the site for documentation
tested brave and edge
these links take me directly to the correct page in edge and chrome normal mode or incognito/inprivate mode.
The links you mention are not redirects either, they are direct links.
Maybe the logging console might have a clue, but try it on a different machine or network is all I can recommend at this point.
is there no documentation download or anything? even in a private window with adblock off its the same issue
yes the documentation is in the download. Have you tried this on a different machine or network like i said? (even a cell/mobile phone)
