I’m trying to install the oculus spatializer plugin but it doesn’t show up in my FMOD project.
I downloaded the spatializer plugin from here
https://developer.oculus.com/downloads/package/oculus-spatializer-fmod/
And I copied the contents of the studio folder to my FMOD installs plugin folder. I also tried adding it to the projects plugin folder as well.
I am using FMOD 2.01.09
Not sure what else to do. Any help would be great.
Cheers
The instructions aren’t overly clear on this but what you need to do is:
- Identify if you are using the 32 bit or 64 bit version of FMOD Studio. Click Help > About and it should tell you.
- Copy the appropriate dll (x64 or Win32) into the “Plugins” folder in either the FMOD Studio installation folder, the project root folder, or the local AppData folder.
- Copy the contents of the Studio folder into the same folder as step 2.
As an example - here is my project’s Plugin folder:
After restarting FMOD Studio, you should see the Oculus plugins show up in your project’s effects list.
Cheers, that worked, I didn’t realize I needed the DLL file in the x64 folder. I just copied the files from the studio folder.
