I get the following error:
[FMOD] PluginEffectModel::init : Missing DSP plugin 'Resonance Audio Source' UnityEngine.Debug:LogWarning(Object) FMODUnity.RuntimeManager:DEBUG_CALLBACK(DEBUG_FLAGS, IntPtr, Int32, IntPtr, IntPtr) (at XXX/Assets/Plugins/FMOD/src/Runtime/RuntimeManager.cs:36)
I’m not trying to use the resonance audio plugin anymore. Neither in Unity nor in my FMOD-Project.
Also the path “xxx/Assets/Plugins/FMOD/scr/Runtime/RuntimeManager.cs:36” is not the same as the
project path of my Unity-Project and doesn’t exist anymore. (It was an older version of the project).
I don’t get why FMOD tries to use this older version of the RuntimeManager. I updated the path of the FMOD-Project in Unity under FMOD/Edit Settings.
Because of this error my bank will not load properly. Can anyone help?
