I’m Mathieu a young game designer. I’m creating the prototype of a new game that I want to market using EU4. Since 3 weeks, I try to launch the game on Android with sound but… without crashes (what I didn’t succeed with the audio system of UE4, I always have crashes when I play just 5 simple sounds at the same time. Not to mention the inability to use functions such as pitch, etc. on Android with the UE4 audio system… so not cool).
So, I tried FMOD which seems very powerful and maybe less a source of crashes (finger crossing).
I tried to build Unreal Engine from source (obligatory right ?) to use FMOD correctly with my Android project but I always have problems that I don’t find how to fix :
After trying to integrate Wwise, I became aware of some steps and I retried the integration of Fmod.
I finally succeeded yesterday evening late in the night!
If someone has the same difficulty to make it works on Android, I can explain tricky steps on demand ;).
However I can not play the game in “Launch Preview” mode (I saw other people with the same problem) but I can properly test the game in package mode! Yeeha!
Hi, I have trouble intergrating the .So libraries from the low level programmer’s API, as the project builds, but on the device(galaxy S5) it simply crashes before the app can open. Any help would be greatly appreciated thanks!
I’ve had a look at that compile error message in the first link, that is due to a change in 4.11 to the UnrealBuildTool. We’ll fix up the documentation for Android/4.11 but for now if you get UE4 from github, making sure you choose the 4.10 branch, you can avoid that.
The message about not loading FMODStudio failed to load is usually due to a mismatched version, such as using the plugin with a different engine version, or perhaps not rebuilding the plugin binaries when rebuilding the engine from github.
