Hi there, im either missing units or things have been changed? i cannot find any runtime.manager nodes etc to be able to use fmod in visual scripting. Any help would be great!
Thanks
Thanks
Which version of FMOD and Visual Scripting are you using?
There is a known error with Visual Scripting version 1.7.8. Previous versions of the package still work.
Thanks for the reply! Latest version of Fmod 2.02.11 and visual script 1.7.8. How would i install a previous version?
Upon further investigation, Unity has removed any version of Visual Scripting older than the current version, as far as I can find. You can use Bolt, the original version of Visual Scripting however, it does not seem compatible with versions of Unity older than 2020.
Sorry for the inconvenience, if we find a solution for Visual Scripting 1.7.8 I will let you know.
