FMOD-Unity 5 Parameter Trigger
(Gina Zdanowicz) #1
Hello, I am an audio designer and new to C# so please excuse any mistakes I have made in my code.
I have a simple first person scene in Unity 5 and I am working on this footstep script so as the camera moves across the terrain the steps will trigger. I was able to get a single event to trigger but when I updated the script to include the parameter I am getting all sort of errors. This is one of the errors “error CS1547: Keyword `void’ cannot be used in this context”
Any tips on how to clean this up would be very much appreciated.
using UnityEngine;
using System.Collections;
public class Footsteps : MonoBehaviour {
[FMODUnity.EventRef]     //Declare FMOD event (can also declare snapshots and parameters)
private FMOD.Studio.EventInstance footsteps;
private FMOD.Studio.ParameterInstance Material;
float footstepTimer = 0.0f;
Vector3 lastPos = new Vector3(0, 0, 0);
void Update () {
    bool isMoving = false;
    Transform thisTransform = (Transform)GetComponent("Transform");
    if (lastPos.x != thisTransform.position.x || lastPos.y != thisTransform.position.y)
        isMoving = true;
    lastPos = thisTransform.position;
    if (/*Input.GetAxis("Horizontal") != 0.0f || Input.GetAxis("Vertical") != 0.0f ||*/ isMoving)
        if (footstepTimer > 0.40f)
			footsteps = FMOD_StudioSystem.instance.GetEvent ("event:/footsteps");
			if (footsteps.getParameter ("Material", out Material) != FMOD.RESULT.OK) {
				Debug.LogError ("Can't find Material parameter on the event");
			musicEvent.start();
		void OnTriggerEnter (Collider other) {
			if (other.tag == "Grass") {
				Material.setValue (1);
			if (other.tag == "Wood") {
				Material.setValue (2);
			if (other.tag == "Dirt") {
				Material.setValue (3);
	      void OnTriggerExit (Collider other) {
			if (other.tag == "Grass" || other.tag == "Wood" || other.tag == "Dirt") {
				Material.setValue (0);
        footstepTimer += Time.deltaTime;
(Nicholas Wilcox) #2
This is a generic C# coding error. You’ve put the functions OnTriggerEnter OnTriggerExit inside another function which is not valid code.
using UnityEngine;
    void Update () {
            isMoving = true;
                musicEvent.start();
(Gina Zdanowicz) #3
Thank you Nicholas. I suspected this may be the issue and am trying to work out how to untangle this.
(Gina Zdanowicz) #4
Thanks again Nicholas! Your help is much appreciated. I was able to get it all working with your code fix and after realizing I was using the old FMOD_StudioSystem.instance.GetEvent. I checked out the 2.0 migration doc and see I needed to use the FMODUnity.RuntimeManager.CreateInstance.
