When building for Xbox One with Unity 2019.3.10f1, using fmodstudio20008xboxone_xdk180712.unitypackage, I get an error stating Unable to locate ‘G:Data/Plugins/FMOD/lib/xboxone/fmodstudio.dll’.
In Unity the dll’s reside in the FMOD/lib/xboxone folder, but they end up in ‘G:Data/Plugins/’ in the build. If I manually add the folders after the build is finished, and move the dll’s, it all works fine.
Is there some additional set up I need for making the folder structure correct in the build?
