result = eventInstance.getChannelGroup(out channelGroup);
if (result != FMOD.RESULT.OK)
Debug.Log(FMOD.Error.String(result));
The specified resource is not loaded, so it can’t be unloaded.
UnityEngine.Debug:Log(Object)
Above is the code and the error i get. The event is created and is playing back in unity. I’m not sure why I can’t return it’s channel group? any ideas?
It is not possible to get the ChannelGroup until the Event Instance is successfully loaded. Try to loop until the result is FMOD.RESULT.OK. I do that in a coroutine like this:
IEnumerator GetChannelGroup()
if (instance.isValid())
while (instance.getChannelGroup(out channelGroup) != FMOD.RESULT.OK)
yield return new WaitForEndOfFrame();
// do stuff
else
Debug.Log("Instance not valid");
yield return null;
Hey, I kinda thought this might be the issue! but i never tried it out for some reason. Thank you so much for your reply, extremely helpful!
