How can I get the master channel from a concrete event? I’m trying to change the frequency of the entire event.
Thanks
Thanks
You can change the pitch of an entire Event using: EventInstance::setPitch
Manually digging in to the channels and changing frequency isn’t really advised as it can wreak havoc on the playback system, especially if you are trying to play things backwards with a negative frequency.
Using setPitch doesn’t solve my problem. I need setFrequency because I want it to go really slowmotion, and setPitch only allows me like +/-24st. Please let me know if it’s possible to get the master channel and change its frequency.
Thanks
To get the master channel of an Event, you can use:
EventInstance::getChannelGroup
For further discussion on Event frequency see this post.
