Haptics in Unity-FMOD?
Hi, I’m a student sound designer currently working on an indie project using Unity 6 and FMOD 2.03.
I’ve been teaching myself FMOD and technical sound design, and I’m trying to figure out the most professional way to build a haptic architecture.
Recently, I’ve been experimenting with Meta Haptics Studio to convert audio into haptic signals. My current workflow is dragging the generated haptic assets directly into FMOD tracks (on a separate track within an event) so they trigger alongside the sound.
I have a few questions regarding this:
1 - Is this a viable professional workflow? Is it common to manage haptics as tracks within FMOD, or is it generally better to handle haptic triggers on the Unity/Engine side?
2 - Platform Compatibility: Does this FMOD-track-based approach work reliably when porting to consoles like the PS5 (DualSense), or is it mostly optimized for Meta Quest/Android?
3 - Performance: Are there any known issues regarding synchronization or CPU overhead when running haptics through FMOD events like this?
Since I’m learning this on my own, any advice on “Industry Standard” for Haptic vs. Sound architecture would be incredibly helpful. Thanks!
  1. FMOD is an industry standard tool and FMOD Haptics has been used in many projects already. However, how you handle haptics will strongly depend on the project. FMOD Haptics aims to make it easy to create, audition and build with haptics.
  2. FMOD Haptics is cross platform and natively supports PS5. More info about the affect FMOD Haptic effect can be found here: FMOD Engine | Effects Reference - Performance::Haptics
  3. Referring to the above docs: “Haptics is a low overhead effect.”
Hope this helps.
